So I ran into a hiccup with rear swap... any tips...
well just noticed something I didn't catch earlier...
apparently a '02 ws6 rear has 2 seperate abs sensors, one for each wheel.
while a my '00 does not, has a single sensor over the diff. I guess apparently v6 rears are different then v8s in more then one way.
Any suggestions on how to fix this?
-drill a hole in teh top of the diff housing, pull out the diff, put a abs ring on the diff, put it all back in.
-swap the gears to my old diff, move my abs reluctor ring to the new diff or keep it on my current diff and slap it all in there.
ok cool looks like I can jsut hook it up to read on sensor.
I'll just slap it on and figure abs sensor issue out later ;)
PS so much easier removing suspension parts of my '00 then back in teh day from my 94.
we have a third bedroom in our townhome you can have it!
I plan to figure it out later. I am assuming I will have to use one for the new rear.
Originally posted by Pewter2K1: Did that work?? No ABS lights or anything?? Cause i think the PCM wouldnt recognize that little gear as opposed to the reluctor wheel...
I don't think the EBTCM will even know the difference. It won't know if the sensor it's reading is in the diff housing or on a certain wheel.
You won't have a problem. The connector for the single is the same as the dual channel - just missing 2 wires.
The brake lines are a different story. You will need a flaring tool and cut your old fittings off your old rear to reuse on the new rear lines. Check out my site for details.
Originally posted by FunkZ: You won't have a problem. The connector for the single is the same as the dual channel - just missing 2 wires.
I just swapped all my hardlines over, no issues. But I need to do something about the sensor.
