Had one on my car for well over a year, with no problems. Set on the hardest setting. According to most of the people on here my tranny should be fried? Is it? Nope
B&M electronic shift improver
White 94 3.4 A4 Camaro<br />Perf:<a href=\"http://www.splmeter.com/94camaro.html\" target=\"_blank\">2.5\" Flowmaster catback </a>, K&N FIPK, B&M ShiftPlus, Aluminum Driveshaft<br />App: 17\" Eagle 077 wheels, rk sport performance spoiler, clear corners<br />Audio: <a href=\"http://www.splmeter.com/box.html\" target=\"_blank\">Drivers side 12\" stealth box</a><br />Times: 10.602@64.2 w/ 2.25 60\' in the 1/8th
6 shooter you dont have a 3.8 f body do you? if so how did you get those numbers? 15s and 98 mph? i bet it is g tech isnt it? i doubt you trap 98 mph running 15s in a 3.8 f body.Longtubes, true duals, ram air, caspers tps tec, ls1 26lb injectors, supersix powerpack, heads milled .020, comp cam .507 220/224 114 ls, forged internals and chromeoly pushrods, bored .030 over, tb spacer, tranny built with stiffer springs and kevlar bands, bigger servo, transgo stage 3 shift kit, edge 3600 stall, 1 pc aluminum ds, 3.73 superior gears, lsd rear ,custom pcm tuning, walbro 255 in tank,
