Topic says it. Ive got a bent rear left axle. from a curbing a long time ago, Its slowing my car down cause my rotor and brakes are rubbing about 3/4ths the time the wheel spins. I need to get a replacement but Dont want to go somewhere really. was wondering if anyone knew where I could pick one up. and if there was only OEM parts avalible.
Bent Rear axle
Axle shaft??? or the axle tube/housing?
Try contacting Mark over at HPSalvage.com he should be able to get a hold of one for you.
An axle shaft swap would take about an hour, if you didn't know what you were doing and took your time!
[ July 04, 2003: Message edited by: Bliggida ]</p><b>15.41</b> @ 89.80 & 15.45 @ <b>91.64</b>, 2.21 60ft, 3,440 raceweight, using <b>OEM</b> Equipment. <br />\'98 L67/M49 w/ 134,000 miles before spun bearing. \"<i>It\'s all stock, Baby</i>!\"
find out what it costs, but over all with new rotors and pads and a used rear axle swap, I put in a lt1 rear axle with 3.42s, LSD, and disc brakes for abotu $500 total, and $383 for the used axle to be shipped from www.speedautomotive.com.
Jsut keep it in mind when you get into pricing things. I had a pinion seal leak and a bad axle, was cheaper to do the swap then fix everything.
hehe, Ive got disc brakes, 3.42s so the only difference would be that it wasnt bent and I could say I had a sports rear. Yea, like I was talkin with my tire guy and he said installed he fix the rear for 300. It was like 196 for the part new. ... still contemplating97 Special Edition Bird , Short bus stlye special
