SLP Calibrator - FirebirdV6.com/CamaroV6.com Message Board
SLP Calibrator
  • SLP Calibrator
    Hi everyone,
    I was wondering if someone may know about this...I have a '99 Camaro w/3.73 ratio gears and I'm trying to install the SLP calibrator. I hooked up all the wires correctly and played with the test dip switches per the instructions. I got the red test light to come on but when setting the 2 & 3 switches to on, the speedometer should go to 110mph and then peg itself respectively. That never happened. Also, there are 2 green lights on the calibrator ..output and input light. The output light turned green but the input light never came on at all.
    Anyone have these problems before?
    Thanks
    A4?
    I have the exact same problem.
      You are out of luck. SLP calibrators do not work. I have tried to argue this fact with them, but they claim that mine worked fine on the bench. I explained to them that it would test fine but wouldn't give any indication while driving. They asked if I had a good ground. WTF? I work on 30+ million dollar aircraft; I think I would know how to wire up a 4 wire system. I still haven't recieved money back or any kind of reimbersement from them. They still have the "calibrator". They've had it for 2.5 months now.
      SLP Can suck my B@lls before I ever support their company again. :mad: [img]graemlins/thumbsdown.gif[/img]
      \" As being is to becoming, so is pure itellect to opinion, so is science to belief, and understanding to the peception of shadows.\" - Plato
        Mine works great!
        Teal 94 Camaro 3.4 Liter<br />Transgo stage 3 shiftkit, Shift module, corvette servo, SLP cold air induction,3.42 ring and pinion, Heavy Duty Posi LSD, Flowmaster exhaust, NX, blackouts
          It's a problem with the 3.8L's. The calibrator kills the pcm signal.
