<blockquote>quote:</font><hr>Originally posted by slacker69: You have to have a lockup for a daily driver<hr></blockquote>
Yeah, otherwise you'll run at higher rpms all the time, and probably ruin that tranny pretty quickly. I think there are some guys on the board with non-lockups though.
<b>1998 Firebird 3800 Series II, A4</b><br />Direct-Flo Lid,K&N Filter,DEE TB Spacer,TPS-TEC,ZZP Mini-AFC,Raised and Cutout Airbox 7mm,BMR STB & Boxed LCAs,KYB AGX Shocks,Drilled/Slotted Rotors,180* Thermo,2.5\" Catco Cat,Dynomax 2.75\" custom catback,Kumho Ecstas/245,Jet Stage 2,3.42,Edge Racing 2870 Stall,B&M Tranny Cooler,B&M Deep Tranny Pan,LSD,AAM Girdle,1LE DS,NX Wet Kit,MSD DIS-4,MSD Blaster Coil Packs,Taylor Spiro Pro 8mm Wires,NGK TR6\'S gapped .045,ZZP UD WP Pulley,SLP Fan Switch,TT II\'s<br />N/A: 15.6342 @ 88.44 (On stock converter. Strugglin\' to beat it.)<br />Nitrous 50 Shot: 14.7463 @ 93.49
My only issue is they have a low torque multiplication factor.
Sure effeciency is up but.......
I run a 3200, 2.8 mult and 95.5 - 96% effeciency.
Typically I see 2.2 or 2.3
Any reason why?
<blockquote>quote:</font><hr>Originally posted by 12secondv6: My only issue is they have a low torque multiplication factor.
Any reason why?<hr></blockquote>
Please give us a chance to get some numbers at the track. Few, if any of us guys with the Edge Racing converters have your experience at the track, so it's gonna take us awhile.
<blockquote>quote:</font><hr>Originally posted by AMinor65:
Please give us a chance to get some numbers at the track. Few, if any of us guys with the Edge Racing converters have your experience at the track, so it's gonna take us awhile.<hr></blockquote>
Oh, I agree it DOES take a decent amount of track time to learn the converter.
I'll admit, I'm probably still learning for n/a runs w/ the converter and nitorus runs, well, I just spin [img]smile.gif[/img]
You could be only seeing 2.3 or so because when yank or PI build a converter for us they dont do as much reasearch on our motor and TQ curve, also buy lowering gears and porting the heads and intanks you have changed and raised your TQ curve.
<blockquote>quote:</font><hr>Originally posted by slacker69: You could be only seeing 2.3 or so because when yank or PI build a converter for us they dont do as much reasearch on our motor and TQ curve, also buy lowering gears and porting the heads and intanks you have changed and raised your TQ curve.<hr></blockquote>
Well, I understand what you are saying but when I called Yank I explained my situation.
I told them I had a 12 second v6 powered nitrous car.
At the time I was running 12.8 with a best of 1.731 60 ft on a stock converter.
I gave them dyno numbers (peak hp, tq, n/a and nitrous etc) tire height, gear ratio, vehicle weight, what I want from it, nitrous was primary goals, n/a was secondary.
I told them I am looking for the best thing I could possibly get.
I explained that I was one of the quicker v6's out there (4th gen f body) and I had been contacted by a magazine at that time.
It took 1 day to make.
I explained I did not want a generic LT1 version.
I have a nitrous converter
Eh, I dunno. I don't want my post to come off as a bash Edge.
This is a new converter for 1/2 the price of what I paid.
The proof will be in 1/4 et's, mph's, 60's and dyno numbers BEFORE and AFTER the converter
well u see my times but i am sure u want more than one
To get a higher str andre will hok you up im sure, some guys preferences are that they wanta lower str but andre will build one with a higher str im sure.
Longtubes, true duals, ram air, caspers tps tec, ls1 26lb injectors, supersix powerpack, heads milled .020, comp cam .507 220/224 114 ls, forged internals and chromeoly pushrods, bored .030 over, tb spacer, tranny built with stiffer springs and kevlar bands, bigger servo, transgo stage 3 shift kit, edge 3600 stall, 1 pc aluminum ds, 3.73 superior gears, lsd rear ,custom pcm tuning, walbro 255 in tank,
<blockquote>quote:</font><hr>Originally posted by SLOWBRAEATER: To get a higher str andre will hok you up im sure, some guys preferences are that they wanta lower str but andre will build one with a higher str im sure.<hr></blockquote>
2.6 str for mine. launches pretty hard with small amounts of throttle.
