New Gears and LSD - FirebirdV6.com/CamaroV6.com Message Board
New Gears and LSD
  • New Gears and LSD
    I want to get 3.42s with LSD for my car, I believe it has 3.08s now. Is this what I would need? http://slponline.com/view_product.asp?PARTNUMBER=64501T What else (besides the gears) would I need? And is it an easy install or should I get someone to do it for me. Also, dont I have to get my chip reprogrammed?
    1995 3.4L A4 Firebird White w/T-Tops *SOLD*<br />**NEW CAR**<br />2004 White Cavalier Coupe<br />2.2l ECOtec 5 speed
    <blockquote>quote:</font><hr>Originally posted by Fierdon:
    I want to get 3.42s with LSD for my car, I believe it has 3.08s now. Is this what I would need? http://slponline.com/view_product.asp?PARTNUMBER=64501T What else (besides the gears) would I need? And is it an easy install or should I get someone to do it for me. Also, dont I have to get my chip reprogrammed?<hr></blockquote>
    Yeeup...that's the correct LSD..
    You will also need to purchase the install kit, and an ABS reluctor ring if you mind losing your ABS.
    You do not NEED to get your PCM reprogrammed. Your speedo will be off, but you won't lose any of the performace you gain from the gears without reprogramming.
    As far as the install goes,,if you know your stuff, then give it a shot. It is not an intermediate job to do though.
    94 Camaro 3.4 A4 <br />T-Tops<br />In the process of an LS1 swap.
      Don't forget: Not just the speedo will be off, but the Odometer will be getting false readings also. That means it will show more miles than you actually have when you move from 3.08 to 3.42 ratio gears.
      Jon
      Check out my stable of supercharged W-Bodies <a href=\"http://www.fullthrottlev6.com/forums/vbgarage.php?do=view&id=136\" target=\"_blank\">HERE</a><br /><b>\'97 Pontiac GP GTP Coupe</b><br /><b>\'98 Regal GS | L67 3800 Series II</b>
        Shift points will be off as well. I just went through this and you will need some kind of recalibrating.....
        Eric
        Eric
        2005 Mustang 4.0
        1996 Camaro Conv
        2000 Ford Excursion
        "Darkness Falls"
          You have 3.23 gears. All 3.4 fbods have them. I would suggest 3.73 gears. They aren't as bad on mileage as everyone thinks, plus there wont be much of a differance between 3.23 and 3.42
          1994 Chevrolet Camaro 3.4L A4 (160hp 200tq)<br />2006 Nissan 350Z 3.5L M6 (300hp 260tq)
            <blockquote>quote:</font><hr>Originally posted by Harry94:
            You have 3.23 gears. All 3.4 fbods have them. I would suggest 3.73 gears. They aren't as bad on mileage as everyone thinks, plus there wont be much of a differance between 3.23 and 3.42<hr></blockquote>
            question. I am going from 323 to 373 and adding a zexel LSD so i will have to get my chip reprogrammed? Have not heard this yet? Let me know [img]graemlins/burnout.gif[/img]
            <a href=\"http://members.cardomain.com/99gatorbird\" target=\"_blank\">http://members.cardomain.com/99gatorbird</a><br />99 Ram Air V6, 18\" Z06 Rims, WS6 Ram Air Style Hood and Lower airbox, Center Force Dual Friction, 3.42 GM Gears, Zexel-Torsen LSD, Free Mods, Dynomax Ultra Flow, Custom Interior, Several Decals from firebats cave<p>9/14/03<br />1/8- 10.45 @ 66.72<br />(I know i can do better)
              If you want your speedo to read correct then yes. I haven't reprogrammed my car yet. My gears/LSD have been installed for a few months now. The speedo is 10mph fast.
