3rd Gear Falls off too Far?? - FirebirdV6.com/CamaroV6.com Message Board
  • 3rd Gear Falls off too Far??
    I havea 2001 with an A4, when under full acceration 1-2 shifts where its supposed to, but on the 2-3 shift it shifts at the right point, but falls off a little too far and slows the car down a bit. Is there anything out there that will fix this? I am not worried about shift points cause the car already shifts every gear right before the limiter/redline.
    Is this somthing a Corvette Servo could fix? Can someone please explain a Corvette Servo to me? Or anything that I can do to help thrid stay in the powerband on the shift?
    Thanks in Advance
    [ February 10, 2003: Message edited by: Pewter2K1 ]</p>
    Anyone? at least tell me about the corvette servo...
      all you can do is change the gearing in the transmission and it would be really expensive to do....
        or you could get more power so the drop off isnt so apparent
        98 Jeep Grand Cherokee 5.9 Limited<br /><br /><br />MODS:<br />180* t-stat, K&N FIPK, mopar ECU,<br />mike leach long tube headers+3\" y-pipe, 3\" all the way out flowmaster 50 series, mopar magnum 2bbl m1 intake manifold, APS 52mm throttle body, powerslots, 2 JL 10w3\'s
