fo it needs a new u joint ? nos that one is ursif u want. i am winning it at 24.50 with a max bid of 25. feel free to outbid me i found another one that ends tonight.
aluminum drive shaft worth it ?
The caps and needle bearings are missing on the rear joint where it bolts to the pinion flange. You can't reuse your stock caps because they're injection molded which is why you need the propane torch... you have to heat them up until the plastic ring inside melts just to get them off. Aftermarket joints come with C-clips to hold it in place. It should only be a 20-40 minute job to change out that joint.
Just to swap the driveshaft, if you're not changing the U-joints, there's nothing special required. It's a simple bolt-on affair.1994 Firebird 3.4<br />15.65 @ 86.8<br /><a href=\"http://www.funkz.net/firebird.htm\" target=\"_blank\">funkz.net/firebird</a><br /><a href=\"http://mywebpages.comcast.net/funkz/timeslips.htm\" target=\"_blank\">Timeslips</a>
well guys i won one wonight and it looks to be a good deal. http://cgi.ebay.com/ebaymotors/ws/eB...ABCA%3AUS%3A11
thats the one i won. lemme know what you guys think.1997 Camaro LS1 RS
1994 Camaro - Sold
1999 Trans am Vert - Sold
A Few Mods....
.2 off your 1/4 mile.. nice i am going to have to buy one, any ls1/lt1/trans am will fit into my 98 firebird correct?
are both of these aluminum?
http://i11.ebayimg.com/03/i/00/94/2c/bd_1.JPG
http://i5.ebayimg.com/01/i/05/5a/da/28_1.JPG
how do you tell the difference between aluminum/steel?
what what length driveshaft would i need?
49 5/8, 41 3/4, 49 7/8
here are the weight specs on drive shafts...
(9.6 for carbon fiber, 12 aluminum and 17lbs for steel)
and a pic of a CF one...(only 779.99 and it can be yours :eek: )
http://tbyrne.com/ls1/carbonshsft.jpg
[ November 07, 2005, 11:09 AM: Message edited by: Matt G ]<b><a href=\"http://www.cardomain.com/ride/2288859\" target=\"_blank\">1999 Mustang GT(Car Domain)</a><br /><a href=\"http://www.cardomain.com/ride/2123740\" target=\"_blank\">1998 Pontiac Firebird(Car Domain) *SOLD*</a></b> <br /><br /><a href=\"http://www.camarov6.com/cgi-bin/ultimatebb.cgi?ubb=get_topic;f=9;t=000902\" target=\"_blank\"><b>PA</b> - Maple Grove Test\'N\'Tune <i>April 15th</i></a>
