Edge Converter - FirebirdV6.com/CamaroV6.com Message Board
Edge Converter
  • Edge Converter
    I did alot of research and considering the street edge converter w/lockup from edge converters. I was thinking about a 3400 stall. Is that about right with 3.42 gears? Also looking into the transgo shift kit (stage 2) with corvette servo from kdsperformance for only 105. Opinions appreciated.
    Hey, shortdog. I ordered a "Street Edge" 2800 stall with lockup. You gotta have lockup, and they're lockup works smooth as factory or better. They told me it turned out to be 2870 true stall 2.33str, 97% efficiency. It flashes between 3100 and 3200 rpm. Very streetable. My shifts are the same as they were prior to install, not soft or muddy. May be the jet chip fixin' that though, I don't know. At first I thought that the converter was somewhat loose, but it turns out that the shop unhooked my battery for some reason. Once the fuel maps readjusted, I cannot really perceive any significant looseness (if any). Car sure accelerates good! Great converter! I'm lovin' it. Gotta learn how to use it at the track.
    <b>1998 Firebird 3800 Series II, A4</b><br />Direct-Flo Lid,K&N Filter,DEE TB Spacer,TPS-TEC,ZZP Mini-AFC,Raised and Cutout Airbox 7mm,BMR STB & Boxed LCAs,KYB AGX Shocks,Drilled/Slotted Rotors,180* Thermo,2.5\" Catco Cat,Dynomax 2.75\" custom catback,Kumho Ecstas/245,Jet Stage 2,3.42,Edge Racing 2870 Stall,B&M Tranny Cooler,B&M Deep Tranny Pan,LSD,AAM Girdle,1LE DS,NX Wet Kit,MSD DIS-4,MSD Blaster Coil Packs,Taylor Spiro Pro 8mm Wires,NGK TR6\'S gapped .045,ZZP UD WP Pulley,SLP Fan Switch,TT II\'s<br />N/A: 15.6342 @ 88.44 (On stock converter. Strugglin\' to beat it.)<br />Nitrous 50 Shot: 14.7463 @ 93.49
      Please people, NO FLAMING here!!!
      Best of luck with it, I prefer another brand.
      Get some before and after runs so we can see the gains, thanks
        I was scared of this, ok i think its only4u who has the 3600 stall like i do. well if you order a 2800 and it actually fashes 3100 thats 300 rpm off, could this be why only4u isnt having as good of a track time or reduction in et as slacker69? because slackers is advertised 3000 so probably flashes 3300, man i hope this 3600 doesnt flash close to 4000 i will be so upset :(
        [ February 20, 2003: Message edited by: SLOWBRAEATER ]</p>
        Longtubes, true duals, ram air, caspers tps tec, ls1 26lb injectors, supersix powerpack, heads milled .020, comp cam .507 220/224 114 ls, forged internals and chromeoly pushrods, bored .030 over, tb spacer, tranny built with stiffer springs and kevlar bands, bigger servo, transgo stage 3 shift kit, edge 3600 stall, 1 pc aluminum ds, 3.73 superior gears, lsd rear ,custom pcm tuning, walbro 255 in tank,
          i have a edge 3000, flashes 3400 on n20.. i love it..
            malloynx, did you switch converters? It's showing in your sig that you have the Yank converter.
              yea i need to update the sig.. also i'll have track times soon with the new verter
                Out of curiousity, why did you switch converters? Also, what's the stall torque ratio you have?
                  ummm i swtich cause of the n20... my edge converter was built with n20 in mind
                  also my str. 2.37
                  i also got all the carbon fiber stuff tey put inside :D
                    <blockquote>quote:</font><hr>Originally posted by SLOWBRAEATER:
                    <hr></blockquote>
                    Though I haven't driven Evan's car, I think that the converter he has is too big for a "street" setup. No offense Evan.
                    Think about it. On a stock converter, you can spin off the line if you flash it. Evan has 3600 2.6x STR. There is no way you can flash that converter on a street setup. The only way that he or even I would be able to realize the full potential of our converters is to run with beefed up drag suspension. I mean slicks, LCAs, torque arm, you name it. Not to leave out great track conditions. He's gonna have to roll into the throttle. I learned that at SLP on Saturday.
                    As far as the stall speed being a little high. That seems to be common with most people with high stall converters on this board.
                      I will most likely be spraying in the future, so that's why I'm thinking between a 3000-3400 stall.
                      [ February 20, 2003: Message edited by: shortdog273 ]</p>
                        yea mine is 3020 n/a and 3400 n20.. and let me tell you, with a 100 shot i spin my dr's with ease// :D
                          Ok, I justed talked with Andre at Edge. I told him I have 3.42s with lsd and wanted my car streetable with not much topend loss. I also mentioned I'll most likely be spraying in the future 100 shot tops. He recommended the street edge 3200 stall with 2.5ish STR and 96-97% eff. will be the best overall choice for my application. Does that sound about right?
                            andre is the man if he recommends that then thats what i would ge, he recommended the 3600 for all my mods.
                              yea i really trust andre. i love my converter and my tires hate it [img]graemlins/evilgrin.gif[/img] . i would go with with he reccomends...
