The LS1 uses a different bellhousing than the LT1, correct? Would it be possible to put the bellhousing from an LT1 onto a LS1 Transmission and put it in a V6 assuming that we have enough torque to power 6th gear? To make the swap possible pedals from an LS1 as well as the console would need to be used. Would the transmission need a different input shaft? Thanks for any input.
6spd Transmission from LS1??
2001 A4 Pewter 75th Anniversary W68 Firebird<br />1997 Dodge Ram Extended Cab 360 CID<br />1996 Ford Explorer V6<br /><i><b>Any number you can think of, I can think of one higher.</b></i><br /><a href=\"http://www.criesmusic.com\" target=\"_blank\">www.criesmusic.com</a><br /><a href=\"http://www.mp3.com/beneaththestage\" target=\"_blank\">www.mp3.com/beneaththestage</a><br /><a href=\"http://www.thenebula.com/carpics/pics/Silver3800V6Picturescar6.jpg\" target=\"_blank\">http://www.thenebula.com/carpics/pics/Silver3800V6Picturescar6.jpg</a><br /><a href=\"http://www.thenebula.com/carpics/pics/Silver3800V6Picturescar4.jpg\" target=\"_blank\">http://www.thenebula.com/carpics/pics/Silver3800V6Picturescar4.jpg</a><br />AIM: Guitarchitect201Tags: None
First off all I don't know if you can make it an exact fit with M6. For autos, 97+ have removable bellhousings. You would still need to swap the input housing cause of the input shaft. But on M6s I can't tell you for sure. I don't know if they also came with removable bellhousings since they don't offer them on V6s.
2000 Firebird convert, chameleon/tan, M5, Y87, TCS, BMR tower brace and panhard, KBDD sfcs, 245/50-16 GSCs
Actually you would want an LT1 T56 it is the same length and bolt pattern as our bellhousings. So no custom driveshaft is needed. I think the T56 would need a new input shaft so that it would match our clutch.2002 M5 Bright Metallic Silver <br />*Fully loaded and modded<br /><br />2005 GSXR 750<br />*Micron Serpent Race Exhaust *K&N Filter *Power Commander *Trying to hit 200 MPH!<br /><br />1970 SS 454 Chevelle Cortez Silver<br />*It can pass anything but a gas station
Ok, so we would need a LT1 T56 Tranny, Center console for a manual Trans Am, pedals from manual Trans AM, shifter boot, performance shifter, shifter knob, input shaft... What else would be needed for the swap? Thanks
[ July 30, 2002: Message edited by: Silver3800V6FBodyKY ]</p>2001 A4 Pewter 75th Anniversary W68 Firebird<br />1997 Dodge Ram Extended Cab 360 CID<br />1996 Ford Explorer V6<br /><i><b>Any number you can think of, I can think of one higher.</b></i><br /><a href=\"http://www.criesmusic.com\" target=\"_blank\">www.criesmusic.com</a><br /><a href=\"http://www.mp3.com/beneaththestage\" target=\"_blank\">www.mp3.com/beneaththestage</a><br /><a href=\"http://www.thenebula.com/carpics/pics/Silver3800V6Picturescar6.jpg\" target=\"_blank\">http://www.thenebula.com/carpics/pics/Silver3800V6Picturescar6.jpg</a><br /><a href=\"http://www.thenebula.com/carpics/pics/Silver3800V6Picturescar4.jpg\" target=\"_blank\">http://www.thenebula.com/carpics/pics/Silver3800V6Picturescar4.jpg</a><br />AIM: Guitarchitect201
<blockquote>quote:</font><hr>Originally posted by Silver3800V6FBodyKY:
[ July 30, 2002: Message edited by: Silver3800V6FBodyKY ]<hr></blockquote>
You wouldn't need the console assuming yours is a stick or the boot or the knob. The rest you would. Make sure you get the whole clutch pedal assembly because the older T/As use a manual clutch not a hydraulic one.2002 M5 Bright Metallic Silver <br />*Fully loaded and modded<br /><br />2005 GSXR 750<br />*Micron Serpent Race Exhaust *K&N Filter *Power Commander *Trying to hit 200 MPH!<br /><br />1970 SS 454 Chevelle Cortez Silver<br />*It can pass anything but a gas station
<blockquote>quote:</font><hr>Originally posted by Blue Flame V6:
You wouldn't need the console assuming yours is a stick or the boot or the knob. The rest you would. Make sure you get the whole clutch pedal assembly because the older T/As use a manual clutch not a hydraulic one.<hr></blockquote>
I have an A4, so I would need the console, boot, and knob.2001 A4 Pewter 75th Anniversary W68 Firebird<br />1997 Dodge Ram Extended Cab 360 CID<br />1996 Ford Explorer V6<br /><i><b>Any number you can think of, I can think of one higher.</b></i><br /><a href=\"http://www.criesmusic.com\" target=\"_blank\">www.criesmusic.com</a><br /><a href=\"http://www.mp3.com/beneaththestage\" target=\"_blank\">www.mp3.com/beneaththestage</a><br /><a href=\"http://www.thenebula.com/carpics/pics/Silver3800V6Picturescar6.jpg\" target=\"_blank\">http://www.thenebula.com/carpics/pics/Silver3800V6Picturescar6.jpg</a><br /><a href=\"http://www.thenebula.com/carpics/pics/Silver3800V6Picturescar4.jpg\" target=\"_blank\">http://www.thenebula.com/carpics/pics/Silver3800V6Picturescar4.jpg</a><br />AIM: Guitarchitect201
Just an FYI before you purchase anything. I would go to a salvage yard and get some measurements from both bell housings. To my knowledge, GM does not usually use the same bell housings on V6 vs. V8 blocks.
Also get some measurements of the trans mount position. Those brackets will also be different.
If you make some progress with this endevor, please let us know [img]smile.gif[/img]
SteveFirebirdV6.com/CamaroV6.com Administrator
Stupid is rewarded with the ban button.
Official Avatar Nazi according to Meatyshells :D
<blockquote>quote:</font><hr>Originally posted by TealV6:
Steve<hr></blockquote>
Blue Flame V6 said that he successfully bolted on a T-56 from a LT1 at a dealer. So the transmission will bolt up, it's just a matter of the input shaft, and mounting brackets. I'll probably get the transmission, take it to a Transmission Shop and have them prep. it up and install it.2001 A4 Pewter 75th Anniversary W68 Firebird<br />1997 Dodge Ram Extended Cab 360 CID<br />1996 Ford Explorer V6<br /><i><b>Any number you can think of, I can think of one higher.</b></i><br /><a href=\"http://www.criesmusic.com\" target=\"_blank\">www.criesmusic.com</a><br /><a href=\"http://www.mp3.com/beneaththestage\" target=\"_blank\">www.mp3.com/beneaththestage</a><br /><a href=\"http://www.thenebula.com/carpics/pics/Silver3800V6Picturescar6.jpg\" target=\"_blank\">http://www.thenebula.com/carpics/pics/Silver3800V6Picturescar6.jpg</a><br /><a href=\"http://www.thenebula.com/carpics/pics/Silver3800V6Picturescar4.jpg\" target=\"_blank\">http://www.thenebula.com/carpics/pics/Silver3800V6Picturescar4.jpg</a><br />AIM: Guitarchitect201
OK, I can get the T-56 from an LS1 for very cheap. If I did this I would need to get the bellhousing from an LT1, correct? My question is: Is the LT1 and LS1 tranny the same length, cause I don't want to have a custom driveshaft made? Anyone know for sure? Thanks2001 A4 Pewter 75th Anniversary W68 Firebird<br />1997 Dodge Ram Extended Cab 360 CID<br />1996 Ford Explorer V6<br /><i><b>Any number you can think of, I can think of one higher.</b></i><br /><a href=\"http://www.criesmusic.com\" target=\"_blank\">www.criesmusic.com</a><br /><a href=\"http://www.mp3.com/beneaththestage\" target=\"_blank\">www.mp3.com/beneaththestage</a><br /><a href=\"http://www.thenebula.com/carpics/pics/Silver3800V6Picturescar6.jpg\" target=\"_blank\">http://www.thenebula.com/carpics/pics/Silver3800V6Picturescar6.jpg</a><br /><a href=\"http://www.thenebula.com/carpics/pics/Silver3800V6Picturescar4.jpg\" target=\"_blank\">http://www.thenebula.com/carpics/pics/Silver3800V6Picturescar4.jpg</a><br />AIM: Guitarchitect201
Ok, first of all lets think here guys. The transmissions would have to be the same length for both LT1, LS1, and all V6 4th gen f-bodies otherwise an aluminum driveshaft wouldn't be interchangeable between everyone's. I would think the T-56 no matter LT1 or LS1 would swap in to ours without much modification.---<br />-\'95 3.4L M5 Camaro
<blockquote>quote:</font><hr>Originally posted by StockV6Cam:
Ok, first of all lets think here guys. The transmissions would have to be the same length for both LT1, LS1, and all V6 4th gen f-bodies otherwise an aluminum driveshaft wouldn't be interchangeable between everyone's. I would think the T-56 no matter LT1 or LS1 would swap in to ours without much modification.<hr></blockquote>
No actually they aren't the same length because of they moved the motor. That is why a LS1 crossmember won't work for a LT1.2002 M5 Bright Metallic Silver <br />*Fully loaded and modded<br /><br />2005 GSXR 750<br />*Micron Serpent Race Exhaust *K&N Filter *Power Commander *Trying to hit 200 MPH!<br /><br />1970 SS 454 Chevelle Cortez Silver<br />*It can pass anything but a gas station
