does anybody else have this problem with 3.73's and zexel torsen diff. LSD. the problem i have is that every time i hit the brakes i get the low trac light come up in the gauge cluster. it is about every time i am making a turn into a drive way or a quick turn and i press the brake to slow down.
all w/ 3.73 respond....
The problem is not with the 3.73's but with the braking system.
What gear did you have before you had 3.73's? Perhaps you did not upgrade the ABS reluctor if you went from 2 series to 3 series carrier?
Double check teh brake lines again.
How is pedal pressure?Keith - Chicago<br /><a href=\"http://www.hptuners.com\" target=\"_blank\">HP Tuners - PCM Reprogramming</a><br /><a href=\"http://www.dxsoftware.com/magnus/\" target=\"_blank\">97 Firebird V6 to LS1 swap</a><br /><b>V8 9.967@132.78</b> 1.322 60\' NA Heads/Cam<br /><b>V8 10.295@128.48</b> 1.363 60\' NA Cam Only<br /><b>V8 10.987@119.31</b> 1.422 60\' NA Stock Internals<br /><b>V6 13.674@98.22</b> NA<br /><b>V6 12.394@104.91</b> N20 100HP
I dont have that problem, go with what magnus suggested.2002 Maple Red Firebird V6<br />3.73 w/ LSD | Pro-5.0 Shifter | Fan Switch | Tach w/ Shiftlite | Boost and Fuel Pressure Gauge | Bilstein Shocks & 1LE Springs | 1LE 32mm Bar & Poly Bushings, Poly Tranny Mount and Torque Arm Bushing | BMR LCA\'s | Catco 3\" Cat w/ Edlebrock 5509 Muffler, (all 3\") | Corbeau A4 Seats (Pair) |<p><a href=\"http://forums.fakeleg.com/\" target=\"_blank\">http://forums.fakeleg.com</a><br /><a href=\"http://cv6.fakeleg.com/\" target=\"_blank\">http://cv6.fakeleg.com</a> - Part & Repair Manuals and write-ups.
I dont have that problem. The only thing i got is a humm around 50 mph when i have my foot on the gas.Whisper lid PPI amp JL 12\" Bosten 6 1/2 Clear coners <br />K&N And hyper white all around 3.73 auburn posi 180* <br />Mangna Flow TransGo shift kit, Jet chip stage 2 <br />Altezzas (carban fiber) <a href=\"http://members.fbody.com/jdyson209/\" target=\"_blank\">http://members.fbody.com/jdyson209/</a>
<blockquote>quote:</font><hr>Originally posted by wickedties82:
I dont have that problem. The only thing i got is a humm around 50 mph when i have my foot on the gas.<hr></blockquote>
HAHA meee too, i though something was wrong, but i guess not ;p2002 Maple Red Firebird V6<br />3.73 w/ LSD | Pro-5.0 Shifter | Fan Switch | Tach w/ Shiftlite | Boost and Fuel Pressure Gauge | Bilstein Shocks & 1LE Springs | 1LE 32mm Bar & Poly Bushings, Poly Tranny Mount and Torque Arm Bushing | BMR LCA\'s | Catco 3\" Cat w/ Edlebrock 5509 Muffler, (all 3\") | Corbeau A4 Seats (Pair) |<p><a href=\"http://forums.fakeleg.com/\" target=\"_blank\">http://forums.fakeleg.com</a><br /><a href=\"http://cv6.fakeleg.com/\" target=\"_blank\">http://cv6.fakeleg.com</a> - Part & Repair Manuals and write-ups.
by ssms5411About a week ago noticed my brake lights not working also Hazards not working. Installed new brake switch and still not working, checked fuses and what...4 days ago
