That TCS button might also be the reason why I can't powerbrake.
Auto Tranny (A4) Question
<blockquote>quote:</font><hr>Originally posted by shortdog273:
That TCS button might also be the reason why I can't powerbrake.<hr></blockquote>
UH, YEAH :D97 Red Firebird<br />Best N/A 1/4: 13.98<br />Best N/A MPH: 96.13<br />Best Nitrous 1/4: 12.49<br />Best Nitrous MPH: 108.53<p>2001 Pewter Camaro SS <br />GTP Stage II Heads, Pig Cam, Holley Intake, SLP Headers, SLP Lid, Vigalante 3600 Stall Converter, MagnaFlow Cat Back Exhaust, Duel Electric Cut-Outs<br />11.26@121
Are you sure you have a TCS button? I dont think any v6s, i may be wrong, came with TCS. Or are you refferring to your SGS as TCS?2003 Fire Red Dakota R/T 5.9<p>V-Force Exhaust<br />Custom Cold Air Intake
No, actual TCS was offered on 01 and up V6's. It operates on the same principle as ASR and TCS in their big brothers... ie the computer reduces throttle and/or applies the rear brakes to slow the rear wheels.
Don't beleive me, it's option code NW9 on the Firebird/Camaro, just like on the Formula/Z28. Also, looking over the options, I don't see SGS anywhere, which is good, cause SGS is dumb (at least compared to TCS).Matt<br />2000 Firebird<br /><br /><a href=\"http://www.fullthrottlev6.com/forums/index.php?\" target=\"_blank\">FullThrottleV6.com</a>
I am sure it's the TCS button I have. It's right in front of my shifter above my ashtray/lighter. I turned it off, but it turns itself back on after a few minutes.
[ February 02, 2002: Message edited by: shortdog273 ]</p><b>99 Camaro Z28 A4</b><br />R.I.P. 00 Firebird 3.8<br />14.89 @ 90, 2.03 60\'
<blockquote>quote:</font><hr>Originally posted by HAZ-Matt:
Don't beleive me, it's option code NW9 on the Firebird/Camaro, just like on the Formula/Z28. Also, looking over the options, I don't see SGS anywhere, which is good, cause SGS is dumb (at least compared to TCS).<hr></blockquote>
I believe you but you're at least a year off. I have a 2000 and DO have the code NW9 on my door. I'm not sure of the SGS and TCS differences though.<b>99 Camaro Z28 A4</b><br />R.I.P. 00 Firebird 3.8<br />14.89 @ 90, 2.03 60\'
Cool, Do you guys with automatics do your regular driving in 3rd gear?<hr></blockquote>
yes. around town when i'm going 40 or below. excessive shifting into 4th (OD) causes excessive wear on the clutches/bands for the OD clutch pack in the trans. i shift into OD (4th or D on the birds) when cruising over 40.ASE Master, L1, X1, C1. Instructor in automotive systems. 99 3800 4L60E with a few mods and a greatful dead sticker on the back window.
I believe you but you're at least a year off. I have a 2000 and DO have the code NW9 on my door. I'm not sure of the SGS and TCS differences though.<hr></blockquote>
I think it is indeed possible that I am a year off... The reason that I said '01 and up is because I only could verify it for '01 and up, and because when I was shopping for my '00, the salesman said the V6's didn't have TCS, only second gear start (It was funny how this came up, I was asking if they had any on the lot with a Limited Slip Differential, and he thought I meant traction control [img]smile.gif[/img] )Matt<br />2000 Firebird<br /><br /><a href=\"http://www.fullthrottlev6.com/forums/index.php?\" target=\"_blank\">FullThrottleV6.com</a>
I turned the TCS button and tried it in 3rd gear at around 50mph . It still feels the same(slower). When I put it back in drive, you can feel it kick in. Also, the TCS button turns itself back on after several minutes.<b>99 Camaro Z28 A4</b><br />R.I.P. 00 Firebird 3.8<br />14.89 @ 90, 2.03 60\'
I have a question concerning the D and OD selection. If I am driving around in D, and the transmission is actually in 3rd, and then I shift to OD without changing speed, the engine RPM drops nearly 400 rpm. I know I am still in 3rd because there is another shift when I reach 45mph. I assumed this was the torque converter locking up when shifted into OD. Is this assumption correct? The heat generated from the extra slippage in the converter would also increase transmission temps when not driving in OD. I don't see much of a performance advantage here since the converter will unlock when enough throttle is applied; I just wanted to find if my converter lockup assumption was correct :D
[ February 04, 2002: Message edited by: Backfire ]</p>
