Trans install HELP !!!!! - FirebirdV6.com/CamaroV6.com Message Board
  • Trans install HELP !!!!!
    3800 MT5 into a 94 that had a 3.4 MT5, why? Cause the motor was free...and the old one was dead. Now I'm beating my head cause I cant get the damm trans in, I'm getting it up but I cant get it in. No funny comments please. Is the throwout causing this? Is the spring that stiff? Also What tranny fluid does everyone reccomend?
    Thanks
    you know you're asking a lot there.
    You swapped bell housing, right? just making sure 'cause of the starter positions.
    2013 Ram 1500 Big Horn
    94 comero 3.4
      May be a dumb suggestion, but did you use an alignment tool?
      As for trans fluid, I use dextron III with a green transmission additive I bought at autozone. It's only a small bottle and says it helps gears change easier. Worked fine for me.
