I installed (with some help) a specs stage II Clutch. Everything from the install looks good, no check engine lights or anything like that. However, The clutch pedal was very soft (meaning I had to push it all the way down to the floor before I could put it in gear). I have driven 30ish miles and the clutch pedal is getting better (I assume its self adjusting), almost feels like the old clutch felt except little easier to push in. If I get on it just a little (not much) it feels like the clutch catches slowly (hard to describe). Put it this way, I think If I really got on I could not spin the tires in 1st and chirp the tires in 2nd and 3rd (I could easly do this in the factory clutch). Is this normal? Did I forget to do something? When I got home this afternoon the clutch felt like it was catching faster and I may be albe to chirp the tires in 1st.
Side notes:
Yes, I know you have to break in the clutch for 450 miles. Does that mean for the next 450 miles it will be adjusting its self?
Yes, the flywheel was turned.
Everything appears to be in good working order.
[ March 30, 2004, 05:13 PM: Message edited by: Linxs ]
Side notes:
