...just installed the ripper...and well.... - FirebirdV6.com/CamaroV6.com Message Board
  • ...just installed the ripper...and well....
    well it has whined (yes you read it right whined) since i have put it in. anyone wanna take a crack at this one? i have scratched my head enough on this one.
    99\' Camaro v6 T5- SOLD<br />2004 VW Golf TDI
    What's it sound like? When does it do it?
    Matt
    1998 Mystic Teal Camaro M5
      one of the side effects of a stiffer shifter, you get more transmission/driveline noise transmitted up through it. it might subside or you will get used to it over time..
      -Brad
      2000 V-Star Custom 1100
      :rock:
        it sounds like a buzzing like black98 said, i think it may be vibration coming from the tranny itself. it sounds alot like there is a tiny gap of somekind somewhere and its bouncing rappidly, there is no actual physical movement just vibration.... any way to stop it?
          whining, buzzing, same thing [img]tongue.gif[/img]
          mine does the same. my stock shifter and knob did the same especially after i put the poly trans mount in. when i got the stiffer shifter it got worse, but i don't even notice it now.
          to make it really bad, i have to push down in the shifter knob, but how often do you really do that?
            possibly, if its a quick slight buzzing, it may be a damaged 'cup' bit that the shifter ****s in... (dont start, i just woke up ;) )... so u may wanna relace it (cheap part) if that is infact the noise u refer to... if u didnt put any grease on that bit as well, it may be that
            97 camaro<br />black, 5 speed, t-tops, rockford fosgate cd w/4X6.5\" rockford speakers, 3\" flowmaster american thunder catback with 3\" carsound cat, SLP CAI, B&M Ripper w/leather Hurst shift knob, 5% tint.<br /> <a href=\"http://camaroz28.cardomain.com/id/ianwells100\" target=\"_blank\">http://camaroz28.cardomain.com/id/ianwells100</a>
              ya, that cup might be it, and im gunna try the grease. and the Poly tranny mount is next so i might as well get used to it. but ya, it does get worse when i push down on it. ima try those and see where i stand after that. im going by the parts store this thursday... blinker bulb went out... so i'll see if i can pick up that lil plastic cup thingy there.
                Did you put a layer of RTV between the shifter and the transmission?
                1999 red camaro v6 M5: with a turbo<br />13.52@107.99<br />No, seriously: Who Farted? <br /><a href=\"http://www.cardomain.com/memberpage/600086\" target=\"_blank\">http://www.cardomain.com/memberpage/600086</a>
                  that would be a negative sir... dont have any... looks like i'll be picking that up @ the store as well
                    That's exactly it -- the RTV. [img]smile.gif[/img]
                      I have a ripper, RTV applied and I greased the little white cup too, and I still get a buzzing sound. I just turn the radio up and it goes away.
                      -Marc
