Help with thinking ahead... - FirebirdV6.com/CamaroV6.com Message Board
  • Help with thinking ahead...
    Here is my problem - I have 3.08s with an open diffy and I want to convert to 3.42s with LSD.
    However, down the road (maybe a year from now after I have money saved up), I plan on doing the V8 swap. So, as far as my knowledge goes, I am told I need to strengthen the rear end.
    What do I need to do to the rear end to make it strong enough to handle the power of a V8 that is going to be modded? Any general recommendations on switching the differential?
    All input is welcome.
    Tom<br />Too many mods for this sig.<br /><a href=\"http://www.l337server.com/Tom/cars.html\" target=\"_blank\">My car\'s site</a><br /><br /><a href=\"http://www.FullThrottleV6.com\" target=\"_blank\">www.FullThrottleV6.com</a>
    i don't know how much you'll really need to "strengthen" it unless you start putting all kinds of power adders on top of the LS1. the 10 bolt is actually pretty good and adding LSD, from what i have seen, solves a lot of the problems associated with the 10 bolt, especially noise.
    BUT, you could always start with a stud girdle after 3.42s and LSD. they're cheap insurance and make it especially easy to change diff fluid.
      I'm not familiar with a stud girdle.. what is it? Where would you find one?
        http://www.slponline.com/view_produc...RTNUMBER=65004
        that's the AAM version
        http://www.thunderracing.com/catalog...ories&pcid=210
        and the TA version
        you are adding rigidity and reducing heat... and whenever you reduce heat you are stretching out the life of your components :D
          You've got the same rear end as in any LS1 car, and with the take-off LSD you'll have the same differential. You would probably want a 1-piece DS if you dont already have one. But after the swap you'd have basically what LS1 cars come with stock plus the 3.42s since that was also an added option. So you'd be ahead of the game in some respects. You'd be good for quite some time unless you were putting some serious power and stress down on the rear, but the girdle would definitely help extend it's life some also.
          AIM: Alientr8tr<br /><a href=\"http://www.cardomain.com/memberpage/583450\" target=\"_blank\">1998 Camaro 3.8L</a><br />Flowmaster 80-series, !FRA, Eibach Springs, KYB AGX, SLP sway bars, 3.42/LSD, Wings West kit, Z06 Motorsports, Silverstone Metallic paint<br /><a href=\"http://www.shift5.com/\" target=\"_blank\">Shift 5</a> - My Band
            Thanks a lot for the help guys - '99 was the year when they went back to the one piece driveshaft, so I shouldn't have to worry about that. I'll probably look into getting that stud girdle, if for no other reason than to make changing the fluid easier. [img]smile.gif[/img]
            • Manimal
              Coil springs
              by Manimal
              3 days ago
            • Manimal
              Newby here
              by Manimal
