t5 on 3.8 and 3.4 the same and... - FirebirdV6.com/CamaroV6.com Message Board
  • t5 on 3.8 and 3.4 the same and...
    t5 on 3.8 and 3.4 the same and are all t5s the same, like could the one from my 94 camaro v6 work in my 82 z28 or is it weaker
    96 Camaro 3.8 A4 Basemodel: 8 mm wires, Shift Kit, Hollowed <br />Cat(o2 sims), RKSport exhaust, IAT 5.6K resistor, Home Depot CAI<br />&gt;&gt;&gt;15.375 @ 89.27&lt;&lt;&lt;NEW BEST TIME <a href=\"http://www.cardomain.com/memberpage/552491\" target=\"_blank\">http://www.cardomain.com/memberpage/552491</a>
    Are you talking about the t5 connection on the hydrolic clutch line? if yes, I thought 96 and under had a cable clutch line..
    Patrick<br />Sick Sixx Member<br /><b>97 Mystic Teal Camaro</b><br />425RWHP @14PSI<br />Old setup:<br />330RWHP @7PSI 13.9 @ 106.6 <a href=\"http://www.fullthrottlev6.com/forums/vbgarage.php?do=view&id=4\" target=\"_blank\">Mods</a>
      the 93+ have hydraulic clutch systems. Also, you VSS on the older car was cable driven.
        Ahh ok thanks.
          no I mean the t5 manual trans itself. like could it work on my 82 z28. the t5 is out of a 94 v6 car... is it weaker or different from the t5 in the 82 z28?
          just curious
            could you make it fit, bellhousings different or could I just swap the housing from the 82 to the t5 of the 94 and have it work???
              just curious
              Different. I've got close-up pics of both if you'd like to compare.
              The 3rd gen and 4th gen T-5 for the V6 are different.
              Its a no-brainer that the bellhousings are different.
              From my understanding, the internals in the 3rd gen V6 T-5 are weaker then those in the V8 T-5, and I've been told the input shaft is different.
              ~Derrick <a href=\"http://www.appstate.edu/~do54457/\" target=\"_blank\"><i>My Webpage</i></a><br /><b>\'96 3.8L V6 M5 Firebird Y87</b> | <b>162.8 RWHP</b> / <b>196.7 RWTQ</b> <br /><b>•</b> SLP CAI <b>•</b> <a href=\"http://tech.firebirdv6.com/y87.html\" target=\"_blank\"><b>Y87</b> Package</a> - 3.23s <b>•</b> 180º thermo w/ fan switch <b>•</b> TB spacer from DEE<br />1991 Jeep Cherokee Laredo 4x4
                oh ok thanks
