Which would be best? I have a 3.4 with auto. trans. Also does anyone know how much the install costs?? thanks for the help..
3.42 or 3.73
3.42's are the best gears to work with. You can easily reprogram your PCM to correct the speedo, and they won't kill your gas mileage. However, I believe you have 3.23 gears, so you most likely wouldn't feel too much of a difference. I would suggest also purchasing a posi to install with the gears. 3.73's will be faster off the line, but it will hurt your top speed more.
Install varies. Shop around and ask.94 Camaro 3.4 A4 <br />T-Tops<br />In the process of an LS1 swap.
Is it possible that my car has posi or Limited slip? Or is that only with the Z's?1995 3.4-Blackouts, 3 10\" MTX Subs, High flow cat, Faze voltmeter & air/fuel gauges Kenwood 800w amp,80\'s series Flowmaster, . ....more to come
The difference between the two will act simillar to the difference of about 15 horsepower on your particular engine.
Don't worry about top-speed, it WILL NOT be a factor.
So if you have 3.08's now...
3.42's will feel like 17-18 horsepower gained
3.73's will feel like 34 horsepower gained.
[ August 08, 2003: Message edited by: Bliggida ]</p><b>15.41</b> @ 89.80 & 15.45 @ <b>91.64</b>, 2.21 60ft, 3,440 raceweight, using <b>OEM</b> Equipment. <br />\'98 L67/M49 w/ 134,000 miles before spun bearing. \"<i>It\'s all stock, Baby</i>!\"
<blockquote>quote:</font><hr>Originally posted by Bliggida:
<hr></blockquote>
It will be a factor if he doesn't recalibrate his speedo and still has a governor.
Posi came with the Y87 package..check your RPO codes and look for 'Y87'. I doubt you have it though.94 Camaro 3.4 A4 <br />T-Tops<br />In the process of an LS1 swap.
Stock goverened at 115 MPH.
With 3.73's and a 26.18" Wheel diameter means he'll run about 18% slower from his previous top speed - around 93 MPH. That is assuming he does not change or recalibrate his speedometer - which SHOULD be an integral part of swapping gears. In which case he would continue to achieve 115 MPH as he did stock.
Without the Govenor, 3.73's have the possibility of 158 MPH. He ain't gonna pull that!<b>15.41</b> @ 89.80 & 15.45 @ <b>91.64</b>, 2.21 60ft, 3,440 raceweight, using <b>OEM</b> Equipment. <br />\'98 L67/M49 w/ 134,000 miles before spun bearing. \"<i>It\'s all stock, Baby</i>!\"
<blockquote>quote:</font><hr>Originally posted by 95slowcar:
This probably sounds stupid, but what is a RPO code?<hr></blockquote>
No not stupid. Very relavent
Regular Production Order
means it was a factory option you had available to you. Should be series of codes on a sticker in your glovebox. It told the guys on the line what to put into your car - how it was to be built.<b>15.41</b> @ 89.80 & 15.45 @ <b>91.64</b>, 2.21 60ft, 3,440 raceweight, using <b>OEM</b> Equipment. <br />\'98 L67/M49 w/ 134,000 miles before spun bearing. \"<i>It\'s all stock, Baby</i>!\"
RPO codes= Regular Production Order Codes.
They are a list of letters/numbers located on the door jam or in the glove compartment that let you know of the options on your car.
http://tech.firebirdv6.com/RPOcodes.html
There is a list of all of them.
GU4 AXLE REAR, 3.08 RATIO
GU5 AXLE REAR, 3.23 RATIO
GU6 AXLE REAR, 3.42 RATIO
Look for either GU4, GU5, GU6 and that will let you know what gears you have. All the codes are only 3 characters long.94 Camaro 3.4 A4 <br />T-Tops<br />In the process of an LS1 swap.
The 3.73s rock, but your top end is a few mph slower. Unless you are racing I wouldn't worry about not being able to do a sustained 118mph. I top out around 94-100mph.<br /><br /> <a href=\"http://www.cardomain.com/id/nitroxxx28\" target=\"_blank\">http://www.cardomain.com/id/nitroxxx28</a>
Nope, no Y87 :( . Had the GU5 so I guess I ahve 3.23. Ok, thanks for the help ya'll. [img]smile.gif[/img]1995 3.4-Blackouts, 3 10\" MTX Subs, High flow cat, Faze voltmeter & air/fuel gauges Kenwood 800w amp,80\'s series Flowmaster, . ....more to come
Nope, no Y87 :( . Had the GU5 so I guess I ahve 3.23. Ok, thanks for the help ya'll. [img]smile.gif[/img] <hr></blockquote>
Auto's weren't originally equipped with 3.23's were they? It was my understanding that3.23's were a V6 T-5 gearing only.<b>15.41</b> @ 89.80 & 15.45 @ <b>91.64</b>, 2.21 60ft, 3,440 raceweight, using <b>OEM</b> Equipment. <br />\'98 L67/M49 w/ 134,000 miles before spun bearing. \"<i>It\'s all stock, Baby</i>!\"
Interesting...and rare. Its not listed as an option for automatic cars (based on the 1998 Camaro Technical Data released by GM)<b>15.41</b> @ 89.80 & 15.45 @ <b>91.64</b>, 2.21 60ft, 3,440 raceweight, using <b>OEM</b> Equipment. <br />\'98 L67/M49 w/ 134,000 miles before spun bearing. \"<i>It\'s all stock, Baby</i>!\"
by 187sharkHi all new to the community here. I have a 2014 RS 6 speed manual... and so about a year ago my tail lights got cracked and eventually the plastic housing...1 week ago
by ssms5411Still trying to find oil leak on my Camaro, it’s a tough one. I think it is the oil pressure sender myself. Leaking when raving and going into boost....2 weeks ago
