My car has benn doing this for a while now but im kind of concerned about it. It makes a klump sound. It does it when it is moving slowly, but not yet in first gear, if im slowing down to take a corner it does it as i accelerate, out of it. My explanation of the problem is probably hard to follow, but I dont know how else to describe it. Anybody know what the problem might be???
Do I have transmission problems???
tranny mount perhaps\'96 <b>Quasar Blue</b> Firebird A4<br /><a href=\"http://jamiethekiller@comcast.net\" target=\"_blank\"><i>jamiethekiller@comcast.net</i></a><br /><a href=\"http://www.woodlandrock.com\" target=\"_blank\">my band: woodland</a>
thats what mine is doing right now too, but it also does it when i jump on the gas at a low speed... it sounds like a broken tranny mount to me. i think runnin my slicks at the track the other weekend did it in-Aaron, AKA ATL2001<br />93 3.4L <br /><a href=\"http://www.ilfba.com\" target=\"_blank\">www.ilfba.com</a>
If it is a big clunk that you can feel through the center council, then it is probably the tranny mount.
If you can't feel it under you, it could be U-joints, or your gears might have a little play.
There isn't that much that would really make a clunking noise inside an automatic transmission. If the transmission was so far gone as to start making a clunking noise, you would probably notice other problems with it too.<a href=\"http://www.fatninjas.com/camaro\" target=\"_blank\">\'96 Camaro Convertible</a>
<blockquote>quote:</font><hr>Originally posted by StudlyCamaro:
thats what mine is doing right now too, but it also does it when i jump on the gas at a low speed... it sounds like a broken tranny mount to me. i think runnin my slicks at the track the other weekend did it in<hr></blockquote>
Yeah, at low speeds. So it is probably a tranny. mount then. That's not very hard to fix is it??1995 3.4-Blackouts, 3 10\" MTX Subs, High flow cat, Faze voltmeter & air/fuel gauges Kenwood 800w amp,80\'s series Flowmaster, . ....more to come
shouldnt be hard to replace. just get the car on jackstands, then jack up the tranny a bit , remove the bolts holding the mount, pull the mount, then put the new one in, and bolt it up.-Aaron, AKA ATL2001<br />93 3.4L <br /><a href=\"http://www.ilfba.com\" target=\"_blank\">www.ilfba.com</a>
