Just ordered LSD... hows the install? - FirebirdV6.com/CamaroV6.com Message Board
  • Just ordered LSD... hows the install?
    I just ordered the O.E.M. type LSD from SLP cause my base '98 doesn't have the LSD. I was just wondering how hard the install would be, and if it's too hard, then how much should I expect an install to cost at a shop? Also, I should have 3.23 gears, right? Thanks
    <a href=\"http://www.cardomain.com/memberpage/325081\" target=\"_blank\">1998 Red Firebird M5</a><br />not enough mods
    Searching is wonderful! ;)
    http://www.camarov6.com/cgi-bin/ulti...&f=23&t=000006
    http://www.fastblackcar.com/camaro/lsd.htm
    http://www.geocities.com/mustang732/...ac_install.htm
    http://www.geocities.com/d_payton1/g...tallation.html
    If you have an M5, you've got 3.23s.
    If it's an A4 you could have 3.08s or 3.42s. Check you RPO codes. If you've got 3.08s, you'll need new gears and reluctor ring.
    [ August 10, 2003: Message edited by: 98Camaro3.8 ]</p>
    Matt
    1998 Mystic Teal Camaro M5
