2 vs 3 series carrier - FirebirdV6.com/CamaroV6.com Message Board
  • 2 vs 3 series carrier
    i have a question about the 2 and 3-series carriers. in my research i see the carrier mentioned, but never really in a way that answers my question. i have 3.08's on my 97 3.8 and from my research i guess it must be a 2-series carrier. my question, is can i swap out my open differential for posi and install 3.73's which are listed as a 3-series, or do i have to change carriers? is there a problem switching gears that arent the same carrier? and what exaclty is the carrier? is that like the casing, cause i dont think ive ever seen a carrier for sale? secondly, for $500 should i just get a 98 rear axle assemblly with the 3.42 gears, lsd and upgraded bakansia rear rotor package? which install would be esaier in your driveway with limited tools?
    If you buy the SLP LSD and 3.73 gears, you'll be fine. The LSD is the carrier, and the one from SLP is a 3 series.
    Matt
    1998 Mystic Teal Camaro M5
      I wouldn't bother paying extra for those rear rotors, they don't even have much effect on your braking. It's something like 75% is done by the front brakes. Ever notice that's why your fronts always have much more brake dust then the backs?
      AIM: escalier deverre<br />\'02 Pearl Blue Metallic RSX-S (daily driver)<br />\'98 Black Firebird<br />98 V6 turbocharged to 02 LS1 swap<br />\'02 LS1/4L60E<br />LS6 Block, LS6 Intake Manifold, Thunder Racing 215/220 .600/.523/115 Cam, Titanium Retainers, Crane Double Valve Springs, 125 shot NX Wet Kit w/ NOS brand Purge, True Dual \"H\" Pipe w/ two chambers and dumps, 17x11(rear) and 17x9.5(front) Black Powdercoated ZR1 Replicas on 315 and 275 BFGoodrich Comp T/A\'s (Street)/ET Drags/Skinnies on Weldlites(Track), 3.42/LSD
        <blockquote>quote:</font><hr>Originally posted by 98Camaro3.8:
        If you buy the SLP LSD and 3.73 gears, you'll be fine. The LSD is the carrier, and the one from SLP is a 3 series.<hr></blockquote>
        Also, you will have to change the ABS reluctor ring to a series 3 if needed.
        Eric
        Eric
        2005 Mustang 4.0
        1996 Camaro Conv
        2000 Ford Excursion
        "Darkness Falls"
