What is a Rear Tailshaft Housing Seal? - FirebirdV6.com/CamaroV6.com Message Board
  • What is a Rear Tailshaft Housing Seal?
    The Mechanic who changed my oil said this seal was leaking. Is this bad?
    The tailshaft housing seal is the seal around the tailshaft of the transmission. It's where the driveshaft-transmission juncture is. A slow leak isn't something to be immediately concerned with, as long as you check your fluid regularly.
    Replacing the seal is not a difficult job, but will entail changing the transmission fluid and dropping the driveshaft.
    Big cam. Big stall. Big nuts.<br /><br /><a href=\"http://www.streetlethal.net/vids2/joenastycam.MPG\" target=\"_blank\">Idle/Rev Clip.</a>
      Thanks for the info, I know nothing about cars
