question about trashed tranny/clutch... - FirebirdV6.com/CamaroV6.com Message Board
  • question about trashed tranny/clutch...
    Basically after my thrid race tonight at the track, my tranny took a dump...
    feels reall hard to shift, metallic clanking sound that follows revs coming from tranny, sometimes I have a hard tiem getting into first, sometimes I don't. Third, is almot impossible to get into, and the shifter sometimes gets stuck in netural and 4th.
    noises in all gears...
    Any basica ideas of what it might be?
    btw, was rebuilt, resurfaced flywheel, and new OEM clutch in september.
    syncs is my guess, uhh could be that water got in and some how pitted every thing ( this happend in my old 88 ) uhh but my guess is syncs, try double clutching ( let out on the clutch for a sec between gears ) No its not for speed its to get the shaft to spin in compensation of the syncs
    91 Eagle Talon Awd Turbo 5 speed FOR SALE 6000$<br />Looking for a Fiero GT<br /><a href=\"http://www.swdsm.net\" target=\"_blank\">www.swdsm.net</a>
      hmm... could be the synbchros, does liek to kick me out of gears, but a little odd for jsut about all of them to go out at once...
      I doubt water got up in it, the tranny ws rebuilt about 6 months ago.
      [ March 06, 2003: Message edited by: MustangEater8251 ]</p>
        I also want to add... it that when I do get it in gear, it performs normally(other hten horrendous clattering noise) but the clutch doesn't slip, peddle has normal pressure.
        which leads me to believe transmission only related.
          Could be a bent clutch fork and not synchros.
            <blockquote>quote:</font><hr>Originally posted by OneQuickV6:
            Could be a bent clutch fork and not synchros.<hr></blockquote>
            Not sure but it could sound to be that...
            More info I drove it today, dorve 100% fine no slipping on the clutch, no excessive noise, then kerpunk out of now where did what it was doing before... after about 2-3 minutes of driving...
            I drove up in 1st, 2nd, and 3rd, and wound down each gear befoer it started oging out.
            leads meto believe its clutch related...
            Jsut curious do oyu think a shifter might cause this? I am pretty hard on it when I shift gears, worked it loose maybe?
            Just an out there question but worth asking becasue its something cheap and easy to fix.
              TTT
              anyone?
              Funny i am getting more help at a 3rd gen forum, and a forum that supposedly gives no information..
              [ March 08, 2003: Message edited by: MustangEater8251 ]</p>
                I'm having similar problems with my car, but not to the extent that you are. My car seems hard to shift, and it feels (and sounds) like the clutch is slipping some. I'm taking it to the shop on monday. You shouldn't be having problems with your clutch though if it's been replaced pretty recently. I don't know what to tell you
                1994 Med Quasar Blue L32 M5
                Eibach Pro-Kit, KYB Gas-A-Just shocks, K&N filter
                  yours might be your clutch...
                  I might have clutch problems if I messed up my master cylinder but I doubt I did.
                  As for destroying new clutches I ahve done it [img]smile.gif[/img]
                  this is my 4th clutch in the last 30k, and I blew the clutch out in my dads, 2000 when it had 7k on it :D
                    got any lose connections?
                    96 Camaro M5. Dark metallic gree (?dont know the offical color name)<br />Home made Intake :: Headers, 3inch headers back to Flowmaster muffler :: spec stage 3 clutch Now installed, waiting for 3.42\'s and LSD next month<br /><a href=\"http://photobucket.com/albums/y192/RiceEatingCamaro/?action=view&current=newcar.jpg\" target=\"_blank\">My Car</a> <br /><br />Totalled Car.<br /><a href=\"http://bellsouthpwp.net/s/k/sk8er305/\" target=\"_blank\">96 CamaroRS</a>
                      <blockquote>quote:</font><hr>Originally posted by Tyler:
                      got any lose connections?<hr></blockquote>
                      none known...
                      I am going to check it out today some more...
                      I am going to look at my shifter... the rubber boot was put in kinda half assed, maybe shifter was as well...
                      BLutch does have full pressure it feels like.
                        it doesnt seem like it would be the clutch...
                        Good Luck
                          LOL,
                          MustangEater8251 I'm sorry to laugh at this, I'm sure you want to get this problem solved ASAP, but I was reading this and it reminded me of a riddle
                          lol- My tranny's making a noise what am I?
                          *no right answer*
                          *clue* clutch doesnt slip, lod noises
                          *no right answer*
                          *more clues*
                          again, MustangEater8251 I apologize, but I just saw the riddle in this thread and had to laugh :/
                            <blockquote>quote:</font><hr>Originally posted by MrCoffee:
                            <hr></blockquote>
                            Its ok any TTT will help...
                            I am jsut trying to figure this out, if its expensive, this car might be done :(
                              if it is popping out of gears then it is definatley your syncro's, pretty hard to do yourself and should cost around 800 dollars or more to fix.
                              Xnenon headlight conversion<br />k&n cold air induction<br />85 shot of nitrous (NOS)<br />255 lph walbro fuel pump<br />80 series flowmaster<br />z rated 255/50\'s<br />misc. auto meter tach and a-pillar
