HELP: What stall converter should I get??? - FirebirdV6.com/CamaroV6.com Message Board
  • HELP: What stall converter should I get???
    I'm absolutely SOLD on the Street Edge converter, but the question is: what stall should I get? What STR should I get? I'm looking for this to be a 14, maybe even 13-second N/A car. My next big mod will most likely be a new cam. With this in mind, I'm looking for the optimal converter for my future setup.
    to get the most out of your verter, you need to know your max torque and what rpm thats at... your verter should be around 500-700 rpm's lower than your max torque rpm to get the most out of it... i'm still on completely stock engine and i'm running a 2800 stall, and it rocks... hope that helps...
    merlin
    2002 Firebird<br />2003 Yamaha YZF 600R
      Gety a 3000-3300 and as much STR as you can get and as much efficency as possible
        <blockquote>quote:</font><hr>Gety a 3000-3300 and as much STR as you can get and as much efficency as possible<hr></blockquote>
        Doesn't more STR give you less top end efficiency? I thought the best thing was to try to get a balance of good STR and efficiency. I'm confused
          If you have 2.73's, then the higher the STR rating will work better. If you start to go the other way 3.23's, 3.42', 3.73's, then the STR rating should go down accordingly. There is more to it than just this, this is to give you a start of what to look for. Matching the cam (duration at .050 lift, and the lobe centerline) to the TC is the most critical. Who makes this Street Edge converter? and what is the diameter?
            <blockquote>quote:</font><hr>Originally posted by Pro Built Automatics:
            ... Who makes this Street Edge converter? and what is the diameter?<hr></blockquote>
            The diameter is 9.5". I have the Street Edge 2870 stall 2.33str 97%eff. Actually flashes between 3100-3200rpm. I love it! Here's the link:
            http://www.edgeracingconverters.com/
            <b>1998 Firebird 3800 Series II, A4</b><br />Direct-Flo Lid,K&N Filter,DEE TB Spacer,TPS-TEC,ZZP Mini-AFC,Raised and Cutout Airbox 7mm,BMR STB & Boxed LCAs,KYB AGX Shocks,Drilled/Slotted Rotors,180* Thermo,2.5\" Catco Cat,Dynomax 2.75\" custom catback,Kumho Ecstas/245,Jet Stage 2,3.42,Edge Racing 2870 Stall,B&M Tranny Cooler,B&M Deep Tranny Pan,LSD,AAM Girdle,1LE DS,NX Wet Kit,MSD DIS-4,MSD Blaster Coil Packs,Taylor Spiro Pro 8mm Wires,NGK TR6\'S gapped .045,ZZP UD WP Pulley,SLP Fan Switch,TT II\'s<br />N/A: 15.6342 @ 88.44 (On stock converter. Strugglin\' to beat it.)<br />Nitrous 50 Shot: 14.7463 @ 93.49
              Thanks. I am not familiar with their units even though they are only a couple of hours from me. I will have to check them out. Right now I am a distributor for A.C.T's 9.5" MAG & PI's Vigilante. They sound as if they know their stuff.
              [ March 12, 2003: Message edited by: Pro Built Automatics ]</p>
