when i start from a stop i hear this loud clunking noise from the transmission. it's after the clutch is totally engaged. it makes about 2 or 3 loud clunks. it can happen after i shift into 2nd too. the same noise happens if i hit a bump, but it doesn't matter what gear i'm in, it can be 3rd and sometimes even 4th. any ideas?
loud clunking noises from M5
I had the same problem about a year ago. I don't remember exactly what the problem was. I think the transmission mounts had come lose. My mechanic said they were sagging and he replaced them. That solved the problem.97 Silver Camaro M5<br />Y87 Package<br />K&N FIPK<br />Flowmaster 80 Series<br />Mille Miglia MM11-2 18x9 wheels<br />Kumho ECSTA 275/35ZR 18s<br />Centerforce Dual Friction<br />B&M Ripper Shifter<br />1LE Aluminum DS<br />BMR LCA\'S<br />SLP 1.8 Rockers<br />ZZP UD WP Pulley<br />H&R Sport Springs<br />Spohn Adj PHR<br />160* Thermostat
what is the poly mount? is it really a worth while upgrade? does it make a worthwhile difference for the trouble it takes to put it on. where can i get it? how much does it cost?2000 pewter firebird<br />Short Throw Shifter, Whisper Lid, Whisper Ram Air, Holley Filter, B&B Triflo, LSD, BMR LCA, STB, PHR, and sway bars (32/21).<br />Power window conversion
Pretty much any speed shop (definitely your chevy parts house) will have the poly mount in stock, they will probably tell you it won't work on your car if they don't know much about the f-body. Mine was something like or under $20. It is nice to have, especially with an aftermarket shifter, sicne it keeps your new toy from jumping up and down and makes it easier to find that 3rd gear when you're racing. I love mine.<a href=\"http://www.fullthrottlev6.com\" target=\"_blank\">www.fullthrottlev6.com</a> THE SOURCE!
