Zexel Torsen “Missing Parts” - FirebirdV6.com/CamaroV6.com Message Board
  • #31
    Originally posted by slow6:
    whats his name ?
    Mark Stevens
    2002 Z28 A4
    SLP Lid | TSP Rumbler | P&P Throttle Body | No Cats | 3.42s | M/T Drag Radials | No Front Sway Bar
    12.76 @ 108.42 w/ 1.90 60’
    • #32
      Originally posted by L36Camaro:
      One more thing, I just looked up the part number on the side of my Torsen, and it says 9032, which means it’s a 2 Series! If I buy the Paddle Kit “4 Series Gear Adapter” from SLP I can still use my Torsen, right? Here is some info about it:
      Torsen Part Number: 409160-9032 (Low Numeric)
      Torsen Diff. Type: T-2
      Bias Ratio: 2.1:1
      Differential Size: 7.6" (7 5/8")
      No. of R/G Bolt Holes: 10
      No. of Splines: 28
      Here’s the link to that info:
      http://www.torsen.com/distributors/4091609032.htm
      Here’s what SLP says about the Paddle Kit:
      New from SLP Performance Parts, this modified paddle-pin kit makes it possible to install 4.10 gears in any OEM or heavy-duty 7.5/7.625" Zexel Torsen differential without grinding the ring gear or center block. SLP strongly recommends the use of this kit for all such installations.
      Can I still use this Torsen?
      2002 Z28 A4
      • #33
        i have my torsen that i am gonna install if you want me to snap a few pics i can. but if its a 2 series i think you cant put 4:10's on it someone correct me if i'm wrong
        1997 Camaro LS1 RS
        1994 Camaro - Sold
        1999 Trans am Vert - Sold
        A Few Mods....
        • #34
          As it is, no. Series 3 gears will not directly work on a series 2 carrier. You'd need to get a special spacer to offset the ring gear.
          You got totally ripped. Did he say what gears he was running when he sold it, or did you not ask?
          Matt
          1998 Mystic Teal Camaro M5
          • #35
            I’m COMPLETELY pissed off now!!!
            He said, and I quote “SLP 3 Series Posi unit from a 2002 Formula”.
            Should I just get my money back?
            2002 Z28 A4
            • #36
              Originally posted by 98Camaro3.8:
              Call up the seller and start *****ing. Then demand your money back because he sent you a useless piece of scrap metal.
              Matt
              • #37
                This A-HOLE takes days to reply to my emails! I asked him for a refund the other day because of the “missing parts” and he said I was crazy to ask for a refund because of a $10 missing part! I explained to him EXACTLY what I needed w/ detailed pictures, and I even circled what I need! He said that I’m asking for the wrong parts, and all I need is a “bearing cover”! WTF!!! What does he mean by “bearing cover”?
                2002 Z28 A4
                • #38
                  Maybe he's talking about the bearing caps on either side?
                  http://home.hiwaay.net/~sbuc/stalkerv6/torsen-4.jpg
                  Or maybe the races that surround the bearings under the caps?
                  Whatever he says is BS, though.
                  I'd make some noise on the forums that he frequents...make sure no one buys from him again.
                  Matt
                  • #39
                    I'm just going to tell him that my rear end is a 3 series, and the Torsen he sent me is a 2 series. I will give him the Torsen's part #, and a link showing it's a 2 series. Because I know he is going to say that I'm lying, and it is a 3 series! Matt, could you give me a couple links to some Torsens on eBay that YOU think are good deals?
                    BTW, he is "Muncie4sp" on CamaroZ28.com
                    2002 Z28 A4
                    • #40
                      Cool. Thanks man! [img]smile.gif[/img]
                      2002 Z28 A4
                      • #41
                        ok, recieved his real name.
                        whats his EBAY NAME?
                        sorry you got ripped, I did too.
                        at least, the pieces you are missing only
                        cost a max of $20 bones.
                        I can find the seller I bought my
                        "THRUST BLOCK" and
                        "RETAINING BOLT" from.
                        and see if he has more.
                        I think that slp paddle kit will be adequate.
                        you got the T2-R I think. I got a regular Torsen.
                        • #42
                          "THRUST BLOCK" and
                          He is "Muncie4sp" on CamaroZ28.com
                          He doesn’t have an eBay name, only a PayPal ID.
                          I’m trying to get a refund from him, because I can’t use the Torsen he sent me anyway because it’s a 2 Series Carrier, not a 3 Series like I need. Plus he even said, and I quote “SLP 3 Series Posi Unit from a 2002 Formula”, and I had a weird feeling that this was a lie too, so I looked up the part number on the side of the Torsen (9032) which means it’s a 2 Series.
                          2002 Z28 A4
                          • #43
                            i believe this guy has your solution - http://www.ls1tech.com/forums/showthread.php?t=427251
                            1997 Camaro LS1 RS
                            1994 Camaro - Sold
                            A Few Mods....
                            • #44
                              My Torsen is useless to me because it is a 2 Series, not a 3 Series as the guy originally stated. So I’m going to get a refund from the seller and I’m going to buy a Torsen that is a 3 Series and NOT missing ANY parts. Thanks for finding that for me, though. [img]smile.gif[/img]
                              2002 Z28 A4
                              • #45
                                saw this too if ur interested. http://web.camaross.com/forums/showthread.php?t=417133
                                mods - if i cant link to other forums then please delete it.
                                1997 Camaro LS1 RS
                                1994 Camaro - Sold
                                A Few Mods....
