Rear Main Seal Q: - FirebirdV6.com/CamaroV6.com Message Board
Rear Main Seal Q:
  • #16
    Originally posted by kristen:
    so i am spending a pretty penny(hey if you have it spend it)but i want to do it all rather than have to rip it all apart later
    I agree... no need to tell me. After all my issues I said **** it.
    new master
    new slave
    new flywheel
    new clutch
    new fluid
    new pilot bearing
    whole 9 yards.(also did ls1 driveshaft and different rear)
    then 3500 miles later the transmission died, and I STILL had to pull the motherfing tranny out again. [img]graemlins/rofl.gif[/img]
    I didn't do the rear main seal mine looked fine, and figure if it ain't broke don't mess with it.
    • #17
      since you there do every main thing what Eric have listed :
      new slave
      new clutch
      flywheel could be machined
      new pilot bearing
      dont forget TOB.
      new fluid
      For the rear main - it comes in the kit , I got mine from napa. RMS + R cover ghasket.
      make sure you dont use too much of the RTV on the cover. It could plug the coolant passes.
      Someone `ve done it,
      you would hate cofe with cream after that..
      • #18
        what is a rear cover gasket and where does it go. i tryed to order it from a few places and no one could tell me
        WAWA-A-HOLIC
        • #19
          to replace the RMS you have to remove the door/cover where it sits. and you def would have to replace this. Napa have it, I've seen they do have a picture of in on the computer. Also I've seen a write-up on that somewhere , I couldn't find it anymore
          • #20
            my rear cover gasket came with my rear main seal. Its a fel-pro part number BS 40621-1 They call this kit the REAR MAIN BEARING SEAL
            • #21
              Oh and if you want jest the rear main cover gasket its Fel-pro part number 95951
              • #22
                http://cgi.ebay.com/ebaymotors/BS406...spagenameZWD1V This is the kit i bought, its both the main seal and rear cover gasket.
