I don't know where to post this, Nitrous, Drag Racing, or Driveline. Here is the story.
After I did the cam install a few months ago, I upped my nitrous to a 100 shot. I immediatly found that in 1st or 2nd gear all it did was spin my street tires. However, in third it would just spin the stock clutch. So about 2 months ago I put in a Spec Stage 3 clutch. Then, soon afterwards I put on some M/T Street Radials. All seemed fine except I was maxing out my injectors (nothing to do with nitrous, just the cam making the car want lots of fuel). Before I put in the new injectors, I had the car dynoed. It peaked at 231 RWHP N/A but the injectors went static at 5300 rpms. Then I put in 36# injectors and the car is running great. I would think that maybe the injectors gave me 20 more hp. So with the 100 shot I might be around 350 RWHP.
Tonight I went to the track and spun the sh** out of the clutch in every gear. I was logging the run with HP Tuners and you can clearly see the mph climbing slowly but when the nitrous hits, the speed continues to climb slowly but the rpms go right to red line so it is not the tires. Before the injectors the clutch held fine and I was pulling 13.5 1/4 mile times.
I can not understand this. That clutch is rated at 680 hp. I might be at 400 hp at the flywheel but it shouldn't be slipping. I have a buddy with a Spec Stage 3 on his LS1 with 450 RWHP and it has no problem holding. The clutch has all the characteristics of a Stage 3. It shudders when it engages most of the time so I do not think they sent the wrong clutch. It looked like a Stage 3 with 4 or 5 paddles (I don't remember exactly how many). Tommorrow I am calling Spec but the thought of pulling that transmission in my garage again is giving me a headache.
