posi vs. lsd?? - FirebirdV6.com/CamaroV6.com Message Board
posi vs. lsd??
  • posi vs. lsd??
    whats the difference between positracion and limited slip diff., im getting 3.42's and looking for the best traction, what do ya'll think??
    merlin
    2002 Firebird<br />2003 Yamaha YZF 600R
    If your gonna be doing a LOT of drag racing or *cough* street racing then go posi, if not the LSD will be fine. [img]graemlins/burnout.gif[/img] [img]graemlins/burnout.gif[/img] [img]graemlins/burnout.gif[/img]
    2001 Blue Firebird.<br />V6 M5. free ram air mod, 3\" pvc intake, Air temp module, 3\" exhaust, Dynomax 3\"straight through exhaust, O2 sim with off road pipe.<p>Kenwood kdc-mp919 head unit, kfc-628 and kfc-748 amps, Kicker I650 mids/highs, 12\" kenwood WS-303 sub<br /><a href=\"http://www.trafficjamzcaraudio.com\" target=\"_blank\">www.trafficjamzcaraudio.com</a><p>1500 years ago the world was the center of the universe. 500 years ago the world was flat. 15 minutes ago we were alone on this planet. Just think what you will know tomorrow.
      Not true
      The ONLY reason to get a posi over a zexel is if you are making over 600+ ft/lbs of torque. Otherwise, the zexel is superior in every sense of the word.
      Posi uses a clutch, and can at any given time put 70% of the power to one wheel (the slipping one) and 30% to the other (the gripping one), that's as good as it gets.
      Zexel-Torsen however (lsd) has instantaneous power transfer, and can give the gripping wheel well over 30% power, and can even achieve a 50/50 balance between the two wheels.
      So unless if you have a low 11 second car, lsd is the way to go.
      Make no mistake, unless if you need the strength of the clutch type differntial, replacing a lsd with a clutch is a downgrade.
      2001 75th Anniversary V6 Pewter Firebird w/ Chrome Wheels, T-Tops, & Y87<br />Mods: Free Ram Air, !Silencer, Holley Filter, Full 3\" Hooker Catback, 3\" Cat<br />Best time: 15.095 at 90.00 MPH with a 2.127 60\'
