i just got lsd and gears installed, car has been makin a weird noise so i took it to les schwab, they said the lsd fluid is either wrong or just not there, so im guessin the shop didnt put the limited slip aditive in, where can i just get the fluid changed out and the right stuff put in
lsd help
You can get the additive at any auto parts store. Just tell them you need some Limited Slip Differential Friction Modifier. The package will have instructions. You should not have to change the fluid but you might need to take a little out (as much as it takes to fit the additive). Shove a hose in the drain plug, cover the end and pull it out. Pour that in a measuring cup. Do that untill you have removed enough to make room for the additive. After adding the additive, top off the diff.
Good luck.2001 Firebird 3.8L V6 M5,<br />It once had....<br />NX Nitrous Wet Kit, ZZP X-P Hot Cam, <br />3.42 LSD, Pacesetter Headers, <br />36# Injectors, HP Tuners<br />322 RWHP, 379 RWTQ<br />13.596 @ 102.56 w/100 shot
by 187sharkHi all new to the community here. I have a 2014 RS 6 speed manual... and so about a year ago my tail lights got cracked and eventually the plastic housing...1 week ago
by ssms5411Still trying to find oil leak on my Camaro, it’s a tough one. I think it is the oil pressure sender myself. Leaking when raving and going into boost....3 weeks ago
