I just got a free one-piece steel driveshaft from a '99 Camaro in a junkyard! Does anyone have a writeup to swap my old two-piece out for it?
Driveshaft Swap
1. jack up can and support it
2. un do the center bolt on the 2 piece DS (PITA)
3 undo the 4 botls holding the DS to the rear...
4. pull DS to the rear of the car to take it out of the tranny
5. put ne DS in tranny
6. bolt it to rear
7. enjoywww.turbov6camaro.com
1997 3800 Series II Camaro
-Put trans in Neutral and chock front wheels
-Put rear of car on jackstands
-Crawl under and take the two bolts off of the center of the driveshaft, then the 4 bolts that hold the driveshaft to the Pinion Shaft (you can trun the driveshaft to get to the other bolts because you left the trans in neutral)
-Get a rubber mallet or hammer and tap the driveshaft near the u-joints until it comes off at the rear, then slide it out of the trans housing
Reverse for installation. The one-piece will not have the two bolts at the center of the driveshaft, so don't worry if you see those two bolts sitting around after you're done.
All-in-all, it'll take about 1/2 an hour, and it's very easy to do.sigpic
be sure to check the tranny fluid ..... you will loose some.... depend on how you have the car jacked upwww.turbov6camaro.com
Good info to have [img]smile.gif[/img] .
David<a href=\"http://www.cardomain.com/id/diognes56\" target=\"_blank\">-----Let them hate, so long as they also fear.-----</a><br /><br /><a href=\"http://visualjoe.com/sigs/pariah.jpg\" target=\"_blank\">----Surrender to the fantasy of abandonment and see how completely it takes you over.----</a>
by DoodlerHi, everyone. We bought a 97 base model convertible Camaro and someone broke the motor ... Lights were blinking on the dash and that someone ignored the...3 hours ago
