..Was just curious what the maximum mph speeds are in each gear for the M5 3.4 and 3.8's with the 3.23's of course..Unless someone has 3.42's I'd like to know that as well. [img]smile.gif[/img]
Max speeds..
I got mine up to about 140mph a couple of months ago. That was in a 3.8 with a 5 speed and 3.23's.
I was in 5th gear at about 4200rpm. THe gearing would have allowed me to go a lot faster, but I ran out of horsepower. I was accelerating about 1mph every 20seconds.
Since our speedometer only goes up to 125, I used some very crude math to estimate my actual speed. If any of you cynical non believers want to check my math and provide me with a more accurate figure, feel free. I know that I was at 4200rpm, with stock tranny and 3.23s.1999 red camaro v6 M5: with a turbo<br />13.52@107.99<br />No, seriously: Who Farted? <br /><a href=\"http://www.cardomain.com/memberpage/600086\" target=\"_blank\">http://www.cardomain.com/memberpage/600086</a>
See where it says Axle Ratio on the left? Type in 3.23. Done.
Just make sure you're using 1995+ F-Body V6, as it has the correct ratios for an M5 V6.Matt
1998 Mystic Teal Camaro M5
On the dyno with 3.42's in 4th gear at 5700 rpms I hit 129mph. If that is any help.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
On the dyno with 3.42's in 4th gear at 6580 rpms I hit 137mph. If that is any help. :D2001 Firebird 3.8L V6 M5,<br />It once had....<br />NX Nitrous Wet Kit, ZZP X-P Hot Cam, <br />3.42 LSD, Pacesetter Headers, <br />36# Injectors, HP Tuners<br />322 RWHP, 379 RWTQ<br />13.596 @ 102.56 w/100 shot
[ March 03, 2005, 10:32 PM: Message edited by: camaroincal ]
Originally posted by camaroincal:
</font><blockquote>quote:</font><hr />Originally posted by 98Camaro3.8:
Just make sure you're using 1995+ F-Body V6, as it has the correct ratios for an M5 V6.1999 red camaro v6 M5: with a turbo<br />13.52@107.99<br />No, seriously: Who Farted? <br /><a href=\"http://www.cardomain.com/memberpage/600086\" target=\"_blank\">http://www.cardomain.com/memberpage/600086</a>
Hmm, I would think you would have enough power to get to atleast 150, since you run a 13.75 in the 1/4. How fast(mph) can you get 1st, 2nd, 3rd, and 4th gear up to before you hit the limiter?
I reset my rev limiter to 6700, so I don't know how fast I can go in each gear right now. It's pretty fast though. That chart in the link is very accurate. It will tell you.1999 red camaro v6 M5: with a turbo<br />13.52@107.99<br />No, seriously: Who Farted? <br /><a href=\"http://www.cardomain.com/memberpage/600086\" target=\"_blank\">http://www.cardomain.com/memberpage/600086</a>
Originally posted by malice10985:
</font><blockquote>quote:</font><hr />Originally posted by camaroincal:
Either that or the guy that had the car before me had 3.42's installed, but I highly doubt it. What I see as max speeds are redline in my car are like 33 in 1st, 60 in 2nd, and maybe 92-92 in 3rd. That's with 3.23 (supposedly) and 245/50/R16's all the way around.
It also says that with my gearing, I could theoretically reach 220mph at my 6700rpm redline in 5th gear. [img]graemlins/naughty.gif[/img]
Time to see if that new turbo of mine can really make power or not.1999 red camaro v6 M5: with a turbo<br />13.52@107.99<br />No, seriously: Who Farted? <br /><a href=\"http://www.cardomain.com/memberpage/600086\" target=\"_blank\">http://www.cardomain.com/memberpage/600086</a>
by ssms5411So my truck is finally getting some work done, after 17 years, Oil pressure sensor went out and it’s located under the lower intake manifold. Have to...3 weeks ago
