3.73 gears tuning someone help me - FirebirdV6.com/CamaroV6.com Message Board
  • 3.73 gears tuning someone help me
    Ok I got my 3.73 gears done today. Trying to program whit the hypertech tuner there is no 3.73 option I am pretty upset about it :(
    What can I do?
    Is there someone in the Austin area and the surrounding areas able to help me whit this tuning issue?
    I really need your help guys
    Thanks
    headers, high flow cat, slp loudmouth
    powerdyne supercharger 6psi
    GT2 cam. all done by myself :banana:
    Hell yea
    just get the speedometer recalibrator from ZZP or Intense, same thing.
    Works fine, and is $100
    <b><a href=\"http://members.cox.net/95batmobile/d86f.jpg\" target=\"_blank\">Sinister Six©</b></a><br /><a href=\"http://www.sounddomain.com/id/95batmobile\" target=\"_blank\">My \'95 Bird</a><br />I am not afraid of storms, for I am learning how to sail my ship.
      Told you to get a real programmer. ;)
      I don't know what options it gives, but you may be able to adjust the tire size to make up for it.
      Matt
      1998 Mystic Teal Camaro M5
        Man i shoulda listen to you before oh well is done now
        Hell yea
          i will go for it thanks
          will the jet scu2000 work on 3.73
          Hell yea
            I've heard that TSP or someone else who does tuning can do simple gear reprogramming for much cheaper than a full tune. I wanna say I've heard like $85 since it's really quick for them to reprogram for gears. That would be truly reprogrammed rather than having a module trick the pcm into thinking otherwise. Give TSP or one of the sponsors with tuning a call and ask. Can't hurt if anything.
            AIM: Alientr8tr<br /><a href=\"http://www.cardomain.com/memberpage/583450\" target=\"_blank\">1998 Camaro 3.8L</a><br />Flowmaster 80-series, !FRA, Eibach Springs, KYB AGX, SLP sway bars, 3.42/LSD, Wings West kit, Z06 Motorsports, Silverstone Metallic paint<br /><a href=\"http://www.shift5.com/\" target=\"_blank\">Shift 5</a> - My Band
              ^ Get it done right. Contact TSP before you waste another $100 on a recalibrator.
                since we are talking about gears. i hava a a4 live in los angeles. Mods consist of headers, cat back, whisper lid, ram air, and nitrous. Whats is best for me? Considering i am a daily driver. If I get the gears what else to I need. I see at thunderracing.com and texas-speed.com about the girdle. can some one explain thanks. i did the search its funny how the war is started but it did not answer my questions.
                  if you have an A4, 3.42's are good all-round gears. thats what I upgraded to, but I kind of wish that I had went to 3.73's now that there are tuning options to correct for them. The only way I would not recommend 3.73 gears in an A4 now based on my own experience is if you are going to run a turbo, then 3.42's.
                  You will more than likely want to hunt down a posi unit to install at the same time. You will just be spinning that one tire even more and not get the full benefit of the gears if you dont. In which case, find a 3 series differential and matching 3 series gears. You will also need an SLP reluctor ring to keep your ABS operational. Lastly you will want an install kit (if you have a bunch of miles on the rear end, get a full rebuild kit as you will sooner or later need to change the bearings anyway.... might as well do it all at once). You do not need a new girdle. They just help to strengthen things up and allow for more oil capacity to keep things cool.
