I am installing a auburn LSD and 3.42 gears. I am doing it myself. I know some of you have done it before and I was wondering if there was anyhing you could tell me to look out for or be careful of.
posi question.
posi question.
96 3.8 red camaro. <br />headers,cam,valve springs,retainers,auburn lsd,3.73 gears,SLP cold air,accel coils,24lb injectors,8mm plug wires,air temp module,LT1 diveshaft,removed a/c,edelbrock torque arm,spohn LCA\'s and PHRTags: None
No takers huh? Ok, I guess I'll let you know how it goes.96 3.8 red camaro. <br />headers,cam,valve springs,retainers,auburn lsd,3.73 gears,SLP cold air,accel coils,24lb injectors,8mm plug wires,air temp module,LT1 diveshaft,removed a/c,edelbrock torque arm,spohn LCA\'s and PHR
I bought the auburn high performance limited slip differential, and a set of richmond 3.42's. I have had them for about 4 months, and finally got the time to put them in. I know how to do it on a 1974 chevy nova but obviously its gonna be different on my 96. do our axles have C clips or axle caps??96 3.8 red camaro. <br />headers,cam,valve springs,retainers,auburn lsd,3.73 gears,SLP cold air,accel coils,24lb injectors,8mm plug wires,air temp module,LT1 diveshaft,removed a/c,edelbrock torque arm,spohn LCA\'s and PHR
if its c clips its gonna be easy. I have to wait until monday though. Stupid machine shops wont press my bearings on and the only place that'll do it is closed for the weekend. Grrrr.96 3.8 red camaro. <br />headers,cam,valve springs,retainers,auburn lsd,3.73 gears,SLP cold air,accel coils,24lb injectors,8mm plug wires,air temp module,LT1 diveshaft,removed a/c,edelbrock torque arm,spohn LCA\'s and PHR
by ssms5411About a week ago noticed my brake lights not working also Hazards not working. Installed new brake switch and still not working, checked fuses and what...1 day ago
