carrier question with gear and posi install - FirebirdV6.com/CamaroV6.com Message Board
  • carrier question with gear and posi install
    if i install a 3.42 posi from a 3.23 open wat would i do about the carrier, i have no idea what this is about...someone said i may need to ge a new one
    SLP CAI, RK Sport headers, P&Ped heads and intake, GT2 cam, Upgraded valvetrain, Z28 rear axle with 4.10s Tx Spd tune, Z06 rims, 2.5\" exhaust to flowmaster, 160* thermo, B&M ripper, upgraded ignition, rockford fosgate 12\" with sony xplode amp and HU.
    The carrier is the differential. Your posi is the differential, and therefore is the carrier.
    Matt
    1998 Mystic Teal Camaro M5
      explain this to me, when u change from open diff. to lsd... ur changing the carrier then? doesnt this cause a possible problem with the gears, as u've changed the carrier, would u not need the gears 're-pressed' with those fancy specialist tools?
      97 camaro<br />black, 5 speed, t-tops, rockford fosgate cd w/4X6.5\" rockford speakers, 3\" flowmaster american thunder catback with 3\" carsound cat, SLP CAI, B&M Ripper w/leather Hurst shift knob, 5% tint.<br /> <a href=\"http://camaroz28.cardomain.com/id/ianwells100\" target=\"_blank\">http://camaroz28.cardomain.com/id/ianwells100</a>
        A Limited Slip Differential is a completely new differential from the open diffy you've got in there. The gear just bolts directly onto the side of the differential. Only special tool needed is a torque wrench to tighten the bolts correctly.
        If you were only upgrading to a LSD (what I did), then you would take the old one out, unbolt the gear, bolt it onto the new one, and install the LSD.
        Here's a typical rear end. It's not exactly like ours, but close enough.
        http://www.autosite.com/garage/subsys/07-01f.asp
        Matt
          so if i were to buy 3.42 gears and posi, which i am going to do probbly off of ebay, what would i need to do other than buy the gears and posi and install it
            If you're installing new gears, I would take it to a shop to have it done correctly. Tolerances are very tight when it comes to new gears.
            Matt
              yea i would for sure get it done by a shop but heres the site, are these the correct gears and posi to swap in my already existing 3.23 open?
                http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW heres the link to the geas and posi id want to buy,letme know if these wouldwork i i gave them t the shop to install
                  Assuming they're in good shape, it would work fine.
                  Matt
                    yes those willl work will work
                    www.turbov6camaro.com
                    1997 3800 Series II Camaro
                      ok I thought I had this figured out but some of these posts confused me. If I were to go from a 3.08 open diff to an LSD, I thought I needed to get new gears too? Can I really just get the LSD and use my 3.08's?
                      1996 Polo Green Metallic Camaro:<br />SLP CAI, Carsound/Magnaflow 3\" in/out cat, Flowmaster 2.5\" cat-back... sounds great
                        The stock 3.08s will not work with the take-off LSD.
                        Matt
                          the action is for a LSD AND gears
                          [img]graemlins/slap.gif[/img] [img]smile.gif[/img]
                          that is what you need in the action
                            That's what I thought. But I think I might have either misinterpreted this post or am missing something when I read it.
                            From what I bolded in that quote, to me it sounds like he only changed the LSD and kept the old gears? That is what confused me. I thought you needed new gears with the LSD. Am I missing something?
                              Is it because he has the M5 so he had 3.23's, which I think 3.23's have a 3-series carrier and the LSD has a 3-series and the 3.08's are 2-series. Is this why it wouldn't work with the 3.08's or am I still missing sometihng here?
