Time for a gear swap! - FirebirdV6.com/CamaroV6.com Message Board
  • Time for a gear swap!
    Well I think the time has come to do a gear swap. I have a open diff. and 3.23's as of now, and I am going to go with a Zexel LSD and 3.73's. I've got a M5, so shift points aren't a problem. What is a problem, obviously, is the speedo. Since SLP discontinued their Speedo Recalibrator, what should I use 'cause I won't do the swap if the speedo's off.
    Will this thing work?
    http://www.intense-racing.com/Mercha...ategory_Code=T
    I heard that the SLP unit worked on M5's, is this correct? If it is and if I could maybe get a used one, would it work?
    Thanks for any help you guys (and girls) can give me.
    -Andrew
    1998 NBM Pontiac Firebird - LS1/T56 Swap | Pro-Kit Springs & Bilstein HD\'s | BMR LCA\'s | LG Adj. PHR | T-top Conversion | <br /> <a href=\"http://members.cardomain.com/battyv6\" target=\"_blank\">http://members.cardomain.com/battyv6</a>
    Looks like that would work, be sure though I would call and ask just to double check.
    1997 30th Anniversary A4 w/ some mods
      I use the Jet SCU2000. Went through the carwash, damn thing doesnt work now. I'll let everybody know how it works after it comes back from the warranty repair.
      All gone :(<br />Best ET ever: 14.3 (I think)<br />----------------------------<br />Check out my site for exhaust clips, burnouts, and pictures, and the supercharger throttle body mod.<br /><a href=\"http://www.geocities.com/net_addict/index.html\" target=\"_blank\">Click on the Firebird</a>
