I've been having problems with my firebird with a A4 transmission. The last few months the acceleration is very slow (rpms are up but the mph are slow). its not a missfire, clogged cat, water/fuel pump, fuel filter, air filter, wires. I had everything checked. Another thing is the car jerks a lot harder now as well. drives rough. I heard somebody on another form stating they had a broken transmission mount and I got to thinking... could these be the root to my problems? bad hesitation. driving rough/jerking gears, major loss of acceleration power? I've had my car to a dealer and they kept it over night to come with the answer "its fine". I dont' know what to believe anymore lol. help me out guys... you think its possible?
Busted transmission mount??
2002 Firebird Y87 & W68, A4, Magnaflow Exhaust, Whisper lid, K&N, 3.42 gears, LSD<br /><a href=\"http://www.cardomain.com/memberpage/770634/1\" target=\"_blank\">http://www.cardomain.com/memberpage/770634/1</a>Tags: None
Just check it out... won't make you slow, but will give you hesitation off the line.-Eric<br /><a href=\"http://www.cardomain.com/id/mustangeater82\" target=\"_blank\">2000 NBM V6 Camaro 5-speed</a> T-top <i>converted</i><br /><b>14.467@95.45mph</b> <i>$0 in mods</i><br /><i>The member formerly known as MustangEater8251</i>
nahh..if you broke the tranny mount the tranny then just hangs on the crossmember..so you get some thumping when you go over big bumps or launch fast..which would be your tranny thumping and the crossmember and bottom of your car..sounds like something else..im not sure what though..<b>12 SECOND DUAL STAGE DRY NITROUS POWERED 98 A4 V6 CAMARO<br /><a href=\"http://www.mysickcamaro.50megs.com\" target=\"_blank\">www.MySickCamaro.50megs.com</a><br />Best ET: 12.82@103<br />Best MPH: 104.7<br />Best 60\': 1.75 - Stock TC</b><br /> </font><blockquote><font size=\"1\" face=\"Verdana, Helvetica, sans-serif\">quote:</font><hr /><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">Originally posted by Shodown:<br /><strong>1DV6 runs 12\'s...enough said. </strong></font><hr /></blockquote><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">
damn, than that IS whats broken on mine [sorry for hijack [img]tongue.gif[/img] ]... poly time97 Camaro<br />160* thermostat, z28 shock/springs, 3\" Magnaflow cat, 3\" Magnaflow catback, LT1 disc/limslip/3.42 rear, SLP CAI<br /> <a href=\"http://www.cardomain.com/memberpage/609893\" target=\"_blank\">http://www.cardomain.com/memberpage/609893</a>
Originally posted by Savage_Messiah:
damn, than that IS whats broken on mine [sorry for hijack [img]tongue.gif[/img] ]... poly time00 GTP<br />98 Camaro v6<br />See, told ya I\'d be rockin another 4th gen :D<br />V6 & V8 tuning available at <a href=\"http://mysite.verizon.net/whenn1/\" target=\"_blank\">http://mysite.verizon.net/whenn1/</a>
Originally posted by foff667:
</font><blockquote>quote:</font><hr />Originally posted by Savage_Messiah:
damn, than that IS whats broken on mine [sorry for hijack [img]tongue.gif[/img] ]... poly time1997 Cayenne Red Metallic Camaro<br />3.8 V6 M5<br />SLP Cold Air Intake<br />Ceramic Coated Pacesetter Headers <br />Flowmaster American Thunder Catback<br />Full 3.42 & Disc Break Rear End Swap
damn, than that IS whats broken on mine [sorry for hijack [img]tongue.gif[/img] ]... poly time<b>Black</b> 1998 Pontiac <i>Firebird</i> A-4 swap<br />271.4rwhp/259.4rwtq NA<br />13.30@102.44 <br /><a href=\"http://www.freewebs.com/wickedsix98\" target=\"_blank\">www.freewebs.com/wickedsix98</a>
crawled under today, it seems fine :/ anything else that can cause these symptoms?97 Camaro<br />160* thermostat, z28 shock/springs, 3\" Magnaflow cat, 3\" Magnaflow catback, LT1 disc/limslip/3.42 rear, SLP CAI<br /> <a href=\"http://www.cardomain.com/memberpage/609893\" target=\"_blank\">http://www.cardomain.com/memberpage/609893</a>
savage. The only way to tell if your transmission mount is broke is if you go underneath the car and you can lift the transmission upwards towards the inner well. If it lifts without a problem and you see that rubber fitting move.. its broke. But the car will jerk or you will hear a clunk noise when you hammer the car. Otherwise it sounds like your ha ving something to do with the fuel or spark cause those are really the only two things that deal with it. I broke my tranny mount.. its a really loud bang when you hammer it off the line. or clunkish noise
YOu can definitely put a poly on a 5-speed. I have one on my '00. Jsut had to extend the crossmember from what I understand you have to do it with all v6 4th gens.
If you guys ahve 5-speeds, its easy to see if you have a broken mount, just put it in 1st, then get on the gas, let off then get on it, the shifter will bounce up and down, a good inch or so if the mount is busted.-Eric<br /><a href=\"http://www.cardomain.com/id/mustangeater82\" target=\"_blank\">2000 NBM V6 Camaro 5-speed</a> T-top <i>converted</i><br /><b>14.467@95.45mph</b> <i>$0 in mods</i><br /><i>The member formerly known as MustangEater8251</i>
an inch or so?
when you break a tranny mount it can easily go up to 4 or 5 inches of movement.
i threw mine out while squealing threw second gear and the shifter damn near knocked me in the chin.
if you had a broken tranny mount you would know it... everytime you came off the line it would jump up and down, even if I drive it really easy it still wobbles quite a bit.
not just into first either, into any gear where the synchros have to do any kind of work.
Originally posted by Dizturbed One:
also... i have a 92 v6 with a 5 speed and NO ONE makes the mounts anymore...
NO ONE.
Except GM. And they want 140 bucks (with a discount from my buddy that works there even, they quoted me 160 over the phone.)
anybody got an old 90 to 92 5 speed mount lying around? lol
and do a search ;)1978 Formula 461 in progress of being built :rock:
2013 Ram 1500 Big Horn
94 comero 3.4
by 187sharkHi all new to the community here. I have a 2014 RS 6 speed manual... and so about a year ago my tail lights got cracked and eventually the plastic housing...6 days ago
by ssms5411Still trying to find oil leak on my Camaro, it’s a tough one. I think it is the oil pressure sender myself. Leaking when raving and going into boost....2 weeks ago
