Exactly what does this part do, and what kind of damage can it cause to drive it while its "out"?
Carrier Bearing
you can't drive the car, your complete rear differential will not even line up and you will destroy your ring and pinion as soon as you put the car into gear. Bad idea, what the heck are you doing anyway? That bearing is pressed on each side of the carrier or lsd depending on what you have, without it, the bearings will no be there and the rear won't even work.255/50R16 Tires, Pioneer Deck, Pioneer 4 Way speakers, PPI Amps, JL subs, Spec Stage 3 Clutch, Optima Yellow Top
What the heck are you doing with a 2 piece driveshaft still? Get a 1 piece steel (if you can't afford an aluminum one) and call it a day.
- Justin<a href=\"http://www.njfboa.org\" target=\"_blank\">New Jersey F-Body Owners Association</a><br />1987 Camaro LT - 400sbc, Aluminum L98\'s w/valve job, Comp XE 274, Q-Junk 750, 3.23 posi, 4.10\'s soon.<br /><br /><a href=\"http://www.njfboa.org/forums/viewforum.php?f=11\" target=\"_blank\">East Coast F-Body Nationals - August 14, 2005</a>
