electric vs mechanical shift kit - FirebirdV6.com/CamaroV6.com Message Board
  • electric vs mechanical shift kit
    What I have heard is that the electrical shift kit causes the pump in the tranny to wearout really fast. So my question is, just how hard is the "real" shift kit on the tranny? Does it increase line pressure?
    Also on a side note my jet chip stage 2 has been acting up, and it sometimes makes my tranny shift extreemly hard 1st-2nd, and when you put it in gear. I'm assuming that it is calling for max pump pressure from the tranny, but why and why did it develope this shift kit after a period of 2 years, it just started doing it, recently? Any help appreciated.
    Turbocharged and intercooled.<br />17psi(oops), stock fuel pump, no FMU<br /> <a href=\"http://www.cardomain.com/id/phoenix64\" target=\"_blank\">http://www.cardomain.com/id/phoenix64</a> <br />Video: <a href=\"ftp://ftp.pfabrication.com\" target=\"_blank\">ftp://ftp.pfabrication.com</a> Assorted car ****: TurboCamaroFull.
    I've read that whether you chose electrical or mechanical shift kits, they both work by increasing line pressure. I'd like to have a corvette servo, but read that you shouldn't do anything else to increase tranny line pressure if you have a Jet Stage II. Hope this helps.
    <b>1998 Firebird 3800 Series II, A4</b><br />Direct-Flo Lid,K&N Filter,DEE TB Spacer,TPS-TEC,ZZP Mini-AFC,Raised and Cutout Airbox 7mm,BMR STB & Boxed LCAs,KYB AGX Shocks,Drilled/Slotted Rotors,180* Thermo,2.5\" Catco Cat,Dynomax 2.75\" custom catback,Kumho Ecstas/245,Jet Stage 2,3.42,Edge Racing 2870 Stall,B&M Tranny Cooler,B&M Deep Tranny Pan,LSD,AAM Girdle,1LE DS,NX Wet Kit,MSD DIS-4,MSD Blaster Coil Packs,Taylor Spiro Pro 8mm Wires,NGK TR6\'S gapped .045,ZZP UD WP Pulley,SLP Fan Switch,TT II\'s<br />N/A: 15.6342 @ 88.44 (On stock converter. Strugglin\' to beat it.)<br />Nitrous 50 Shot: 14.7463 @ 93.49
      I removed the jet stage 2 from my car, when it started acting up. How can both types of shift kits do the same thing? Why buy an actual if an electronic will do?
        http://www.camarov6.com/cgi-bin/ulti...&f=23&t=000980
        2000 NBM M6 Camaro Z28<br />323/335
