yes i did a search but couldnt pinpoint on astraight answer, I have an M5 and Im wanting to upgrade to a new axle w/ disks and 3.42s or 3.73s, when i do the axle swap, what expenses am i looking at? (like any kinda cables orwhat?) also past posts mentioned tht intense makes techedge recalibrator? I cant see it on their site anymore or maybe im ust blind....would it be cheaper to have my pcm flshed by a dealer? thanx a ton
recalibration and cost question for gear installation
SLP CAI, RK Sport headers, P&Ped heads and intake, GT2 cam, Upgraded valvetrain, Z28 rear axle with 4.10s Tx Spd tune, Z06 rims, 2.5\" exhaust to flowmaster, 160* thermo, B&M ripper, upgraded ignition, rockford fosgate 12\" with sony xplode amp and HU.Tags: None
Well he said he searched and couldn't find an answer. Having spent a lot of time searching I can feel his pain since many times when you search you get conflicting information or just plain wrong information. His questions seem just fine to me.
I did a gear swap but not an axle swap so I can't speak for what you will need for an axle swap.
However, as far as the mini-recalibrator from Intense I believe they have quit selling it. You can still get it from ZZperformance:
http://www.zzperformance.com/zzp/pro...e_mini_src.htm
Getting your PCM flashed from a dealer or custom programming is probably the better way to do it IMHO. (If you can find a dealer that will do it).
Although, please note you can only get your PCM flashed from the dealer if you go with 3.42's as that gear ratio is available from the factory. Anything higher wasn't availabe from the factory so there is no factory program for it.SLP CAI, K&N, Whisper Lid, 180* thermo, manual fan switch, 3.42 gears, Auburn Pro LSD, Wester\'s PCM Tuning, TSP Rumbler, High Flow Cat. Best Time: 9.909@71.58 (1/8 mile)
