hey on the newer v6 do u have to go in and program the ecu to install the shift kit
shift kit
Depending on the year of your car (98+ I believe) you have torque management. Torqe management will reduce the benefits of the shift kit on your car.
There is a person on the board (I believe Timbo) that has had issues with the shift kit and torque management.
Westers custom programming and the HP Tuners product will remove the torque management. (Actually Westers "removes all torque management that can be safely removed")SLP CAI, K&N, Whisper Lid, 180* thermo, manual fan switch, 3.42 gears, Auburn Pro LSD, Wester\'s PCM Tuning, TSP Rumbler, High Flow Cat. Best Time: 9.909@71.58 (1/8 mile)
TSP does as well.... I had mine done last week. We're going over the shift kit now to see what might be wrong with it. I may have to change to a TransGo... ;)2000 Firebird. Whisper Lid, True duals, TSP mail order tune, Built Tranny , TCI 2800 stall verter, B&M tranny cooler, Eaton LSD, 3.42 gears. Current best ET. 15.232 89.09 MPH 2.175 60ft on stock 3.42\'s and open diff.<a href=\"http://www.geocities.c
i heard with computer programming they can pretty much make shifting much more firmer, and makes it pretty much like having a shift kit in the car. Therefore you really don't need one with custom tuning.
Yeah, my shifts are pretty firm with my Wester's programming.
I asked Lyndon (Lyndon Wester is the guys name) about a shift kit and he recommended against a shift kit with his programming. He said they raise the line pressure in the programming and anything that further raises the line pressure could cause tranny problems.
I suppose you could ask him to not mess with the firmness of the shifts and then install a shift kit and be fine. You would have to talk to him to confirm/deny.SLP CAI, K&N, Whisper Lid, 180* thermo, manual fan switch, 3.42 gears, Auburn Pro LSD, Wester\'s PCM Tuning, TSP Rumbler, High Flow Cat. Best Time: 9.909@71.58 (1/8 mile)
I had a TransGo shift kit installed to my car a month ago and I didn't reprogram or remove any "Torque Management" (which by the way I don't know what it does). The kit seems to be working fine. Am i missing something here?
I have a 2002 automatic.
[ June 18, 2004, 12:18 AM: Message edited by: Georghino ]2002 Arctic White Firebird W68<br />Installed: FTRA, Carbon Fiber Whisper Lid, K&N Filter, Transgo Shift Kit, Corvette Servo, 160º Thermostat.<br />Appearance: Potenzas RE750 245\'s, 3M Tint 20% All Around, Clear Corners.<br />FOR SALE: HPP3
Torque Management reduces power during the shift. Supposed to reduce shock to the drivetrain.
The KDS performance website has a FAQ that mentions that torque management may reduce the effectivness of the shift kit. I can neither confirm or deny this. But that is what KDS says (kds sells shift kits for our cars).SLP CAI, K&N, Whisper Lid, 180* thermo, manual fan switch, 3.42 gears, Auburn Pro LSD, Wester\'s PCM Tuning, TSP Rumbler, High Flow Cat. Best Time: 9.909@71.58 (1/8 mile)
Yeah, my 1-2 shift with Westers causes a whip lash motion of my head now.SLP CAI, K&N, Whisper Lid, 180* thermo, manual fan switch, 3.42 gears, Auburn Pro LSD, Wester\'s PCM Tuning, TSP Rumbler, High Flow Cat. Best Time: 9.909@71.58 (1/8 mile)
THe PCM will see the short shifts, and think there's something wrong in the drivetrain, and reduce engine power to protect the drivetrain.
With HP Tuner, you can change your shift times, and either remove, or work around, the torque management.
As to shift kits boosting the line pressure way up, they don't have to. With a good shift kit, you can quicken the shifts, increase the apply speed and holding pressure without going wild with the line pressure.Wife and a dog, they both think they\'re Kujo.<br /> <br />1999 3.8 A4 Y87<br />Navy Blue Metallic<br />BFG G-Force KDWS 275/40/17s, <br />WS6 Wheels (17x9)<br />Phoenix Transmissions 2400 Stall Converter<br />FRA, Holley Powershot filter, Whisper Lid, Ported Throttlebody<br />2000 manifolds, Flowmaster, WS6 Tail Pipes, <br />MSD 8.5mm Wires, MSD Coils, Autolite plugs<br />Performance Cryogenics treated rotors<br />1LE Sway Bars and panhard rod, 1LE front springs w/SLP Bilsteins, stock rear springs w/ 3rd Gen Bilsteins, BMR STB, KBDD SFCs, 1LE rear lower control arms, 1LE front lower control arms<p>1968 Chevelle Malibu 327 TH350
by ssms5411About a week ago noticed my brake lights not working also Hazards not working. Installed new brake switch and still not working, checked fuses and what...3 hours ago
