when I was driving on the express way today I noticed a noise coming from the rear end. Its a low pitch rumble that occurs when im cruising, when i first touch the accelerator or when i let off the accelerator. if im accelerating, Its not there. Im hoping this is all it is. the differential is brand new from jegs as well as the 3.73 gears. they have about 1000 miles on them. I gave them the proper break in time, so I hope its nothing to do with that. The u-joints pretty old though.
bad u-joint???
bad u-joint???
96 3.8 red camaro. <br />headers,cam,valve springs,retainers,auburn lsd,3.73 gears,SLP cold air,accel coils,24lb injectors,8mm plug wires,air temp module,LT1 diveshaft,removed a/c,edelbrock torque arm,spohn LCA\'s and PHRTags: None
Its probably your gears wine.. Is it only there when you are cruising?? When you let off the gas does the noise go away??Jeff ..
1998 Firebird.. Built 3.8 with a 125 shot.. 370rwhp,415rwtq.. stock tune!! sold
2002 WS6 T/A.. Bolt ins..448rwhp
2009 G8 GT.. Vararam intake, GXP axleback
1998 Corvette.. Vararam intake, Ti axleback
http://www.fquick.com/slow-v6
yes. it goes away when i let off the gas. I thought the gear whine would be more like an actual whine though.96 3.8 red camaro. <br />headers,cam,valve springs,retainers,auburn lsd,3.73 gears,SLP cold air,accel coils,24lb injectors,8mm plug wires,air temp module,LT1 diveshaft,removed a/c,edelbrock torque arm,spohn LCA\'s and PHR
Its more like a owl sound.. hoooool.... Thats your Pinion Not properly shimmed.. Its only when you give it gas and put a strain on the rear..Nothing is going to happen just your gears are going to wear out faster..Jeff ..
pinion is fine, I found out what it is. the noise isn't a howl or a whine so i took it to the shop. when they intalled my lsd and gears, they dind't put the washers in between the torque arm and rear end. so there was about 1/2 inch of play. the whole rearend was shifting.96 3.8 red camaro. <br />headers,cam,valve springs,retainers,auburn lsd,3.73 gears,SLP cold air,accel coils,24lb injectors,8mm plug wires,air temp module,LT1 diveshaft,removed a/c,edelbrock torque arm,spohn LCA\'s and PHR
