Ok, yesterday I went on a short road trip to pick up my new headers. When I was no more than 15 miles from being home, my tranny started acting up. All day it was fine, no clunk sounds, no leaks, nothing. I stopped at a light, and when I got back up to speed and went to put it in 5th gear, it wouldn't go. I tried over and over and it still won't go into 5th. Once I stopped again, I tried to go into reverse, same thing. So I am somehow locked out of 5th and reverse. The other four gears function properly. Anyone had any problems like this? What was the problem is similar, and solution? We are planning on dropping the tranny tomorrow or Sunday, and would like some ideas of what is wrong before we dive into it, or if it's bad enough, take it straight to the shop. THANKS.
Tranny problems, HELP!
Does it grind? Explain a little more about the failure to get it into gear.
Reverse is not a syncronized gear, just to make sure. Have you tried putting it in reverse from 4th gear (sitting still of course) to help keep the gears meshed up correctly?
How does your tranny fluid look? Have you checked it?2002 Maple Red Firebird V6<br />3.73 w/ LSD | Pro-5.0 Shifter | Fan Switch | Tach w/ Shiftlite | Boost and Fuel Pressure Gauge | Bilstein Shocks & 1LE Springs | 1LE 32mm Bar & Poly Bushings, Poly Tranny Mount and Torque Arm Bushing | BMR LCA\'s | Catco 3\" Cat w/ Edlebrock 5509 Muffler, (all 3\") | Corbeau A4 Seats (Pair) |<p><a href=\"http://forums.fakeleg.com/\" target=\"_blank\">http://forums.fakeleg.com</a><br /><a href=\"http://cv6.fakeleg.com/\" target=\"_blank\">http://cv6.fakeleg.com</a> - Part & Repair Manuals and write-ups.
There's no grinding...it is as stated above like a wall or something keeping me out of gear. I have tried putting it in all other gears first to get it to go in, no luck. Fluid was changed less than 2 months ago, no leaks still.<a href=\"http://www.fullthrottlev6.com\" target=\"_blank\">www.fullthrottlev6.com</a> THE SOURCE!
by ssms5411About a week ago noticed my brake lights not working also Hazards not working. Installed new brake switch and still not working, checked fuses and what...5 hours ago
