It seems like everyone has overlooked the simplist of causes. Your clutch pedal has a return spring on it... Take a look under the dash before you go through all the trouble of bleeding the system and replacing the fluid. My return spring broke quite some time ago and i now have the "soft" pedal feel that. I can put my foot down on the pedal it it has a bit of movement to it before it actually starts to work the clutch, mind you im just putting my foot on the clutch not pressing it down. Just the initial weight of my foot moves it that little bit. The return spring makes the pedal stiff and would keep this from showing... Please check to see if the spring is broken...
clutch pedal issue
2002 Maple Red Firebird V6<br />3.73 w/ LSD | Pro-5.0 Shifter | Fan Switch | Tach w/ Shiftlite | Boost and Fuel Pressure Gauge | Bilstein Shocks & 1LE Springs | 1LE 32mm Bar & Poly Bushings, Poly Tranny Mount and Torque Arm Bushing | BMR LCA\'s | Catco 3\" Cat w/ Edlebrock 5509 Muffler, (all 3\") | Corbeau A4 Seats (Pair) |<p><a href=\"http://forums.fakeleg.com/\" target=\"_blank\">http://forums.fakeleg.com</a><br /><a href=\"http://cv6.fakeleg.com/\" target=\"_blank\">http://cv6.fakeleg.com</a> - Part & Repair Manuals and write-ups.
thanks for the advice blazzin joe... i'll look at that before i do anything else, but i question, the dead spot gets smaller, then slightly bigger, then really small again...this makes me think its a moisture/air in the fluid thing... but i may be wrong.. [img]smile.gif[/img]97 camaro<br />black, 5 speed, t-tops, rockford fosgate cd w/4X6.5\" rockford speakers, 3\" flowmaster american thunder catback with 3\" carsound cat, SLP CAI, B&M Ripper w/leather Hurst shift knob, 5% tint.<br /> <a href=\"http://camaroz28.cardomain.com/id/ianwells100\" target=\"_blank\">http://camaroz28.cardomain.com/id/ianwells100</a>
<blockquote>quote:</font><hr>Originally posted by Tyler:
lol...right above the clutch line to the slave cylinder is the bleed valve.
it takes two people..
pump the **** out of the clutch like a ****en rabbit about 10 times.. hold it down on the 10th time.. while your holding it down.. have someone under the car opening the valve.. make sure he closes it though before you let off the clutch..
its not brain surgery.. [img]graemlins/stickpoke.gif[/img] [img]graemlins/slap.gif[/img] haha these new smileys are cool<hr></blockquote>
He's dead on here. I just couldn't remember where the bleed screw is... it sticks out of a whole just on to of where the hydraulic line goes into the tranny. It is a long heg shaped thing (not a traditional screw)...1997 Chevrolet Camaro v6 - 13.8@104MPH
1997 Dodge Viper GTS
<blockquote>quote:</font><hr>Originally posted by ianwells100:
thanks for the advice blazzin joe... i'll look at that before i do anything else, but i question, the dead spot gets smaller, then slightly bigger, then really small again...this makes me think its a moisture/air in the fluid thing... but i may be wrong.. [img]smile.gif[/img] <hr></blockquote>
Could be... I always go for the easy to eliminate options before I even consider anything else [img]smile.gif[/img] -- Let us know what happens...2002 Maple Red Firebird V6<br />3.73 w/ LSD | Pro-5.0 Shifter | Fan Switch | Tach w/ Shiftlite | Boost and Fuel Pressure Gauge | Bilstein Shocks & 1LE Springs | 1LE 32mm Bar & Poly Bushings, Poly Tranny Mount and Torque Arm Bushing | BMR LCA\'s | Catco 3\" Cat w/ Edlebrock 5509 Muffler, (all 3\") | Corbeau A4 Seats (Pair) |<p><a href=\"http://forums.fakeleg.com/\" target=\"_blank\">http://forums.fakeleg.com</a><br /><a href=\"http://cv6.fakeleg.com/\" target=\"_blank\">http://cv6.fakeleg.com</a> - Part & Repair Manuals and write-ups.
i'll let everyone know as soon as i do it (but i'm sooo busy with school right now... so it may be waiting a couple of weeks ) [img]graemlins/slap.gif[/img]97 camaro<br />black, 5 speed, t-tops, rockford fosgate cd w/4X6.5\" rockford speakers, 3\" flowmaster american thunder catback with 3\" carsound cat, SLP CAI, B&M Ripper w/leather Hurst shift knob, 5% tint.<br /> <a href=\"http://camaroz28.cardomain.com/id/ianwells100\" target=\"_blank\">http://camaroz28.cardomain.com/id/ianwells100</a>
i forgot to mention to do this a couple of times96 Camaro M5. Dark metallic gree (?dont know the offical color name)<br />Home made Intake :: Headers, 3inch headers back to Flowmaster muffler :: spec stage 3 clutch Now installed, waiting for 3.42\'s and LSD next month<br /><a href=\"http://photobucket.com/albums/y192/RiceEatingCamaro/?action=view¤t=newcar.jpg\" target=\"_blank\">My Car</a> <br /><br />Totalled Car.<br /><a href=\"http://bellsouthpwp.net/s/k/sk8er305/\" target=\"_blank\">96 CamaroRS</a>
