Where's the governor? - FirebirdV6.com/CamaroV6.com Message Board
  • Where's the governor?
    Anyone know the location of the governor on a 700r4? I've heard you can access it by simply removing a cover, is this true.
    I guess nobody has a clue.
      Yes, you can acess it from a cover, but you can't take it off, becuase its around the output shaft before the overdrive unit.
      1999 Pontiac Trans Am M6 Far from stock.....
        Can you access it enough to change the springs and weights?
          Im not totoally sure. I don't think you can, but i could be wrong.
            Yes, you can use a B&M or another brand of governor weight kit. The governor cover is on the drivers side, about 10 inches from the back of the tail housing.
              <blockquote>quote:</font><hr> Yes, you can use a B&M or another brand of governor weight kit. The governor cover is on the drivers side, about 10 inches from the back of the tail housing. <hr></blockquote>
              Ya hes right. Afther I thought about it the goverener is one of the first things you have to take off before you take apart a auto trans.
