lightweight flywheel - FirebirdV6.com/CamaroV6.com Message Board
  • lightweight flywheel
    has anybody used this light weight fly wheel at fttp for $359.10. if im not mistaken, that would gain a lot of performance, but wouldnt it be less street reliable or not even streetable at all?
    Cayenne 1998 Camaro v6 3.8l-<br />HOM ram air, K&N filter, removed MAF screen, EGR block off-<br />more to come...
    Quick revs = difficult to drive.
      thats not the major concern. I thought the way our engine was balenced was the reason why lightweight flywheels are not a good idea.
        Not to mention if you have a manual its VERY difficult to drive and youll stall out quite often.....but for racing its great :D
          I think Ironman24 has one.
          95 Camaro 3.8L Y2K motor <br /><a href=\"http://www.cardomain.com/id/coriya71\" target=\"_blank\">www.cardomain.com/id/coriya71</a>
            just got one ill let you all know in a few weeks
            help me build the ultimate sleeper soon ill have a lot more mods than i can list and watch out for the spikes. 02 firebird
              Revs go up quicker.. revs fall alot quicker as well.
                There is hardly any difference in the way you drive one, and it's not that much more difficult to drive. I've driven Volkswagens that had a 22lb flywheel lightened down to a 7lb, and I didnt have any problems driving it. The little 1.7 8v only had about 100 ft/lbs of torque and no electronic throttle. Half the people on here that diss lightened flywheels have never driven anything with one.
                Brendan
                00 Camaro L36 M49
                84 VW Scirocco 8v
                I am a man, I can change... if I have to.... I guess.....<br /><br />-Red Green
                  Not sure why you would stall out while driving one, but I guess its possible. Although you do trade quicker revs for quicker rev loss regardless.
                    I didnt even know they exsisted on for the 3.8. I remember ssms was going to make one but they ended up scraping the project
                      SPEC has had one for a couple months, most venders advertise them now.
                        i should know mid week. how they handle
                          ok now i know the car was done today. and well the flywheel is ok but if you dont install it just right it isnt balanced so it vibrates really bad at higher rpms like 4k and above
                            would it be possible to take the flywheel to a machinist and get it ballanced or something? it's pretty rediculous to have to do that in the first place tho.
                            Silver \'98 Camaro M5<br />Current MODs:<br />SLP strut tower brace; SLP 1LE swaybars front/back; Powerslot rotors; Hawk pads; Eibach springs; Bilstein SLP shock kit; SLP trans mount; Zexel limited-slip differential; LS1 drive shaft.<br />Possible future MODs:<br />BMR Lower Control Arms; BMR Pandhard Rod.
                              what tyoe of gains did you get? does it hurt daily driver ability?
                              and did you get it installed properly to stop the vibrations?
