Ok, I don't want any "Well maybe, I'm not sure" answers. I have a tranny out of an 01 Mustang V6. If I picked up a belhousing and crossmember from a f-body will it bolt up? Main concerns are: Belhousing bolt up correctly? Driveshaft length? Shifter position (Will I have to chop the floor up a lil?)
[ July 19, 2004, 11:11 PM: Message edited by: Th3 RiCk ]
LOL sry I had too I mean comeon on a Stang tranny in a Comaro...Thats like an Import in a comaro...Ok NOT that bad but still its just WRONG if u ask me.
As far as I know u shouldn't have any problems with a new bellhouseing. Im not 100% sure but I believe the shifter should line up exactly or very close to where only a little moding required.
\"Professionals are predicable, but the world is full of dangerous amatures.\"
No reasons why eh? Stay out of the thread if you're not going to actually be any help. [img]graemlins/twak.gif[/img] [img]graemlins/slap.gif[/img] :mad:
Anyways, I have the tranny laying around because it was swapped into my brothers 5.0, but the speedo and tach were messed up with it. So we found an older tranny from a 5.0 and put it in with no problems.
I think I read somewhere that this particular transmission can be used on s-10's and blazers. My main concern is the dimensions on the transmission.
[ July 20, 2004, 03:25 AM: Message edited by: Th3 RiCk ]
A transmission is a transmission. The same transmission maker (Borg Warner now Tremec I think) is in Dodge, Ford, and GM if I'm not mistaken. Oh, and my car was built in Canada, how about yours? I guess that makes it an Import since technically it was imported. ;)
bellhousing bolt pattern different
bellhousing "twist" different
input shaft different
clutch cable different
ratios (hence speedometer reading) different
ad nauseum
Finally, an intelligent response. Not exactly the one I wanted to hear though. Thanks RallyRed.
The input shaft would be your main concern. The Mustangs use a 10-spline input shaft so it would not adapt. You could always have the input shaft changed, but for the hassle, it would be easier to find a tranny that bolted right up.
I would shut up if I were you, you cant even spell camaro
