manufacturer transmission component slipping - FirebirdV6.com/CamaroV6.com Message Board
  • manufacturer transmission component slipping
    my camaro is a 3.8 with auto trans for a few months now it has been throwing a code p1870 it comes up as manufacturer transmission component slipping i havent had the time or the money to go to the dealer. A guy at autozone was telling me that the dealership has to tell you what the problem is. he says there was a big lawsuit and gm got sued for trying to hide these codes and overcharged people who have to come in and get it checked. does anyone know anything about this. if so please give the name of the lawsuit so i can research it
    96 RS dark green, 1st drag race ever 8/6/04 r/t .126, 1/4..16.142, mph..83.65, home made 3\" exhaust(ill post pics soon)turbo muffler, home made CAI<br /><a href=\"http://www.cardomain.com/memberpage/666045\" target=\"_blank\">http://www.cardomain.com/memberpage/666045</a>
    Call any tranny shop and tell them you need the Sonnax kit. Local shop here said $400 retail. If you've got a friend somewhere, cheaper for sure. Search the tranny section for 1870 and you'll find all kinds of info.
      I paid $300, but yeah, you have the valve body issue. Any reputable tranny shop should be very familiar. Your tranny isn't dying.
      <a href=\"http://www.cardomain.com/id/kefkafloyd\" target=\"_blank\">http://www.cardomain.com/id/kefkafloyd</a> <br />Red 1997 Pontiac Firebird 3.8L A4 w/ Y87
        Do not go to a dealership for this. Go to a tranny specific shop....probably be around 3 to 400 dollars to update your valve body.
        98 firebird A4
          When I changed the tranny oil and filter, I found that the bolts to the valve body were so loose that there was only a couple of turns left before they were going to fall out. Just one more reason why I do my own work, as a in and out place most likey would not have even noticed it. I'm just naturally inclined to check that everything is tight.
          [ July 27, 2004, 02:48 PM: Message edited by: saved1 ]
          95 convertible 3.8 series II
            As far as changing the the tranny fluid, two tranny shops told me not to, that there was so much metal in the fluid that without it the tranny would perform even worse. ive been hesitant to find out.
              What you don't want to do is a transmission flush. You will see it advertised in the local oil change, ac check kind of ads. Our trannys will get damaged if you do this. It really isn't any harder than changing your engine oil. Just jack the car up, remove all of the bolts except for one side and let the fluid drain out, then drop the pan, remove the filter and put the new one in. I don't know why anyone would tell you to leave fluid with metal in it. Where do they find these guys?
                Moving to drivetrain
                White 98 Camaro with t-tops leather and Y87. For more info on mods just ask.<br />1/4=14.9<br />2002 Xterra V6 A4
