Does a 98 posi, fit a 96? - FirebirdV6.com/CamaroV6.com Message Board
  • Does a 98 posi, fit a 96?
    hey, i just bought 3.42s and zexel posi from a 98 firebird, Will there be a problem getting the posi to fit my 96 camaro? And should i replace any other compents such as axle shafts?
    Mystic teal 96 camaro,3.8L, Wings West ground effects, Custom two-tone leather. Fast some day?<br /><a href=\"http://www.cardomain.com/memberpage/463876\" target=\"_blank\">http://www.cardomain.com/memberpage/463876</a>
    it will fit. all components which will need replacing will come in an install kit which the shop should be able to supply you with.
    Visit My F-Body Page
      I have an 02 WS6 rear in my 96 :D
      It will work just fine. Nedd a new ABS relictor ring for sure, other than that I just used the bearings and everything that came with it.
        [QUOTEI have an 02 WS6 rear in my 96 [/QUOTE]
        I have a 01 WS6 rear in my 94...came w/ 3.73's ;)
        So yes it will fit
        94 3.4L A4 white t-tops<br />moroso cai<br />3\"hi-flow pacestter exhaust<br />b&m shift kit<br />catco cat<br />01 T/A rear w/ 3.73\'s and posi<br />1 pc aluminum ds<br />blacked out signals
          All gears/posis for fourth gens are interchangeable as long as you use the correct differential.
          3.08 and lower gears - 2 series differential
          3.23 and higher gears - 3 series differential
          [ November 24, 2003: Message edited by: Stefan ]</p>
