affects of rear gears on the dyno? - FirebirdV6.com/CamaroV6.com Message Board
  • affects of rear gears on the dyno?
    I am wondering, do rear gears affect dyno numbers if the car's computer isn't programmed for them? say, a car went from 3.23's or 3.42's up to 3.73's and didn't reprogram the car's computer. will this make the dyno graph take false readings, since the gears simulate torque multiplication. would torque be off? and since hp is dependent on torque, would hp numbers be off?
    <blockquote>quote:</font><hr>Originally posted by Arctc Wolf:
    I am wondering, do rear gears affect dyno numbers if the car's computer isn't programmed for them? say, a car went from 3.23's or 3.42's up to 3.73's and didn't reprogram the car's computer. will this make the dyno graph take false readings, since the gears simulate torque multiplication. would torque be off? and since hp is dependent on torque, would hp numbers be off?<hr></blockquote>
    I can't answer for torque, but I know the hp will read lower with the higher numerically gear ratio, no matter if the computer was programmed for them or not.
    Chris
    <b>2002 BSM TransAm WS.6 M6</b><br /><b>350rwhp, 365rwtq</b><br /><b>Stock:</b>13.455 @ 105.39 2.129 60\'<br /><b>Mod:</b>12.449 @ 113 1.832 60\'<br /><br /><b>2004 QSM GTO M6</b><br /><b>303rwhp, 329rwtq</b><br />Stock: 13.74 @ 102.14 2.1 60\'<br /><br /> <a href=\"http://members.cardomain.com/silvertaws6\" target=\"_blank\">http://members.cardomain.com/silvertaws6</a> <br /><br /><b>1984 Firebird S/E M5</b><br />2.8L
      Gears shouldnt really have much affect on the dyno, only at the track.
      \"Since I started working, every single day has been worse than the day before, so that every day you see me is the worst day of my life\"
        Lower gears (numerically higher) will soak up a bit of HP on the dyno. But since the machine just takes the HP reading, uses the RPM signal you give it, and make the torque erading from that, you don't have to reprogram to get accurate numbers.
